MrWizard
Traveling
I bought Vulcan brand Square Link Security Chain, and a boron steel hexagon shackle pad lock from Amazon , this stuff isn't cheap
But its a lot less than buying a new Generator or motorcycle,
Made my choices after watching some destructive testing videos online, a locksmith could not cut the. Chain using very large bolt cutters fasten down to his work bench , he used Ratchet Straps or hydraulic rams for applying force to the cutter handles, the cutter jaws gave out and broke with out cutting the chain,
I can explain it to you.
But I Can Not understand it for you !
Connected using T-Mobile Home internet and Visible Phone service
1997 F53 Bounder 36s
ReneeG
Meridian, Idaho
Thanks for all the feedback, all great. We've got a cable in mind, but the key is how to attach it to the truck's bed. We've been looking at a "cleat" that attaches to the inside wall, near the back, that is mainly used for securing motorcycle tie-down straps but most likely will do the job.
2011 Bighorn 3055RL
2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley TrailerSaver BD3
1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica and Mabel, both Rat Terriers!
Gdetrailer
PA
ReneeG wrote: Thanks for all the feedback, all great. We've got a cable in mind, but the key is how to attach it to the truck's bed. We've been looking at a "cleat" that attaches to the inside wall, near the back, that is mainly used for securing motorcycle tie-down straps but most likely will do the job.
One might wish to think about the damage that might be imposed on your vehicle when a determined thief decides they need it more than you.
Don't know about your truck but forceful removal of the built in cleats could cost thousands in damages to your truck to repair..
Chains and cables are casual thieves deterrents, for determined thieves just a speed bump in the road that slows them down by seconds. A HF battery powered angle grinder outfitted with a metal cutting wheel can easily cut through most cables and chains withing a couple of seconds and pretty quietly. I have used angle grinder with metal cutting wheel to remove a rusted/stuck lock with hardened shackle, lock was no match for that cutting wheel and was off in less than one minute.
Heck they may even take a shot at your vehicles cat converters while at it just for spite of making it harder to take and you won't know the cats are gone until you start the vehicle.
Your best line of defense is to hide the gens in plain sight, hard bed cover reduces the off chance of becoming a target and even a soft bed cover most likely will be more effective than a big wire or chain. If they can't see it, they won't know it is there to take.
My gen sits under a hard cover..
fj12ryder
Platte City, MO
With the availability of cordless angle grinders, no cable or chain is "theft-proof" anymore. A good cutoff wheel will go through any of them quickly. But they are LOUD, so if you're nearby you should be alerted, or somebody should. Cables and chains will stop the casual thief, but a determined thief will find away. All you can do is make it as inconvenient as possible.
Howard and Peggy
"Don't Panic"
Gdetrailer
PA
fj12ryder wrote: With the availability of cordless angle grinders, no cable or chain is "theft-proof" anymore. A good cutoff wheel will go through any of them quickly. But they are LOUD, so if you're nearby you should be alerted, or somebody should. Cables and chains will stop the casual thief, but a determined thief will find away. All you can do is make it as inconvenient as possible.
Big grinders, yes, they are loud, small "die grinders" with 3" wheels, not so much. I haven't found many "quiet" campgrounds either, always a lot of background noise all the way up to "quiet time".
ReneeG
Meridian, Idaho
We are looking at Lockstraps. Check that out.
ReneeG
Meridian, Idaho
MrWizard wrote: I bought Vulcan brand Square Link Security Chain, and a boron steel hexagon shackle pad lock from Amazon , this stuff isn't cheap
Thank you. We're checking on the chain and lock right now. This may be our best option, with concealing the generator in our bays when not in use same as we do our current single one.
TravelinDog
Nevada
I keep my gen chained in the truck bed along with a 2nd spare tire. It weighs 140lbs+. If someone really wanted to steal it no "special" cable or lock is going to stop them.
I agree that most thieves just look for an opportunity to grab something loose and easy to take.
Just say no to the payload police ">
Gdetrailer
PA
ReneeG wrote: We are looking at Lockstraps. Check that out.
"as seen on TV" "shark tank" product..
![[image]](http://www.sherv.net/cm/emoticons/hand-gestures/facepalm-hand-gesture-smiley-emoticon.gif)
Might stop a knife, but a steel cutoff wheel the cable won't stand a chance.
You say you store your other gen when not in use, store both in similar manor when not in use..
Someone nuts enough to take a running gen out of ones truck bed while you are there takes guts, determination and a lot of stupidity.. Stymie stupidity enough and they may be stupid enough to cause more problems..
Personally, if I felt this insecure at a campground, I would be packing up and finding one that is less seedy.
ReneeG
Meridian, Idaho
Gdetrailer wrote: ReneeG wrote: We are looking at Lockstraps. Check that out.
We ordered the vulcan chains.
It's not the campground necessarily, but more transit security. Once we're at camp, we'll store it in the basement.
