RV.Net Open Roads Forum: Technology Corner: Windows 11 ..headaches..
 > Windows 11 ..headaches..
DD716TED
Washington State
Posted: 07/28/22 03:47pm Link  |  Quote  |  Print  |  Notify Moderator
I have a new Dell All-in-one Windows 11 computer.. My question is sound.. I want to be able to used the audio out jack for the stereo/speakers on patio and at the same time listen to the computers speakers in my shop... I can get the audio out jack to supply output to the stereo but am unable to listen to computers built in speakers at same time.. and when I unplug the audio out jack, the computers internal speakers work.. I want to use both at same time but haven't figured out how to do it..Utube has been of no help...Anyone else experience or solve this Win 11 hurdle?
bgum
South Louisiana
Posted: 07/28/22 04:25pm Link  |  Quote  |  Print  |  Notify Moderator
Would wireless speakers help?
rk911
DuPage County
Posted: 07/28/22 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
second the notion of bluetooth speakers. or use two sets of wired speakers with an audio splitter coming out of the speaker jack into the splitter and then out from there to each set of speakers. personally i think the BT speakers are your best bet.
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
theoldwizard1
SE MI
Posted: 07/28/22 05:35pm Link  |  Quote  |  Print  |  Notify Moderator
This a very "old fashioned" thing. Sometimes there is actually switch built into the audio output jack. When you plug in the external speakers it turns off in internal ones. Because this is mechanical, Windows has no control.
Buying wireless speakers would help because Windows can control them. Bluetooth has a limited distance.
agesilaus
North Florida
Posted: 07/28/22 06:17pm Link  |  Quote  |  Print  |  Notify Moderator
Don't know anything about all in ones, but the audio driver control panel is where you probably need to be. Realtek is very common on PCs and Notebooks
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
Superbumper
ReneeG
Meridian, Idaho
Posted: 07/28/22 06:33pm Link  |  Quote  |  Print  |  Notify Moderator
This is not a Win 11 issue, but a hardware issue. It's the way things work. You can get a secondary as suggested, or an Amazon Echo. You can't Bluetooth two separate devices to one computer. Even Bluetooth operates this way.
2011 Bighorn 3055RL
2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley TrailerSaver BD3
1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica and Mabel, both Rat Terriers!
obgraham
TriCites WA
Posted: 07/28/22 09:34pm Link  |  Quote  |  Print  |  Notify Moderator
This is why we hang on to old tablet computers. You can sometimes use them to do a single job, perhaps like this one.
Posted: 07/29/22 04:48am Link  |  Quote  |  Print  |  Notify Moderator
In the old days the headphone jack disconnected the internal speakers mechanically (A switch built into the jack) Today I see you can pick and choose electronically (Menu choice) But I now of no way to run both at the same time.. IN some cases I have even more choices. but never more than one at the same time.
Suggestion is a 2 part
Part 1 product link
Part 2 @ Staples.
Note you can often get both from same supplier
THe advantage of the Logitec speakers is they too have a volume control. And generally better sound quality than the built in speakers.
Healeyman
Carrollton, TX
Posted: 07/29/22 11:51am Link  |  Quote  |  Print  |  Notify Moderator
THIS should do it.
https://www.amazon.com/Headphone-Splitte........fix=audio+cab,aps,707&sr=8-2-spons&psc=1
Plug the splitter into the computer audio jack.
That will send the audio signal to BOTH output jacks.
Plug a speaker set into each output jack.
OOPS! wa8yxm had the splitter first.
Tim
DD716TED
Washington State
Posted: 07/29/22 12:28pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the comments / inputs..But I want to use the computers internal built in speakers as well as an amplifier connected to the audio line out jack..seems as though Dell has decided it is one or the other.. Might just go back to the splitter on the line out jack to 2 separate amplifiers as with the old computer and forget the built in computer speakers.. Just trying to reduce clutter on desk..
