RV.Net Open Roads Forum: Tech Issues: Side door latch/lock won't close without assist...
 > Side door latch/lock won't close without assist...
wnjj
Cornelius, Oregon
Posted: 08/09/22 08:25pm Link  |  Quote  |  Print  |  Notify Moderator
If you want to try a cheap fix first, wrap a wide zip-tie or two around the bolt (inside the yellow circle in your photo) instead of gluing blocks in. A zip-tie shim will stay in place much better.
SJ-Chris
San Jose, Ca
Posted: 08/10/22 01:53pm Link  |  Quote  |  Print  |  Notify Moderator
Someone pointed me to this video which shows someone repairing a TriMark latch unit. I think it is just what I was looking for and I'm putting it here in case someone else is wondering about the interior of this latch.
https://www.youtube.com/watch?v=Epq8MrrRF7c
About 1 minute into the video, it shows the little white plastic piece and where it goes. That is the main thing I was trying to figure out as I believe it is what is supposed to keep the springy latch from extending too far (and thus making it so the door won't close without assistance). I'm going to check it out on my latch later today to see if I can get that piece to fit in the right place. I'll report back...
-Chris
San Jose, CA
Own two 2015 Thor Majestic 28a Class C RVs
Rick Jay
Greater Springfield area, MA
Posted: 08/10/22 05:10pm Link  |  Quote  |  Print  |  Notify Moderator
SJ-Chris,
Our rig was built in 2004, and it was about 2014 the original lock mechanism broke. I replaced the entire assembly at that time and it, too, had the pot metal bolt.
The video you posted wiped away some cobwebs. I DID buy a new lock assembly the second time, but a few months later someone posted a link to somebody who manufactured new, bolts. I ended up buying one and replacing the one on my second lock set BEFORE it broke. As an FYI, I think Tri-Mark came out with the new model around 2014 or 2015? Maybe?
I do know the link of the person selling the new kit was posted on these forums back then. I'll see if I can find it.
~Rick
On Edit: No luck finding it yet. I do believe it was a one-man show who designed and built the replacement lock-bolt kit and I believe sold them through E-Bay. Again...cloudy memory. Perhaps with the new design, it wasn't worth him to continue making them? I'll keep looking, though, and if I do find anything, I'll be sure to post it. I think it was $29 or somewhere in that area, which is A LOT cheaper than replacing the entire assembly.
* This post was edited 08/10/22 05:35pm by Rick Jay *
2005 Georgie Boy Cruise Master 3625 DS on a Workhorse W-22
Rick, Gail, 1 girl (26-Angel since 2008), 1 girl (21), 2 boys (22 & 19).
2001 Honda Odyssey, Demco Aluminator tow bar & tow plate, SMI Silent Partner brake controller.
wnjj
Cornelius, Oregon
Posted: 08/10/22 07:56pm Link  |  Quote  |  Print  |  Notify Moderator
-Chris
I looked pretty close at the video and I don't think that plastic piece will stop the out travel. If anything it cusions/guides the in travel. Notice how his remade piece still rests on those two black plastic tabs.
Is it possible to shim the lock inward away from the door edge? If you take out the mounting screws you may be able to place something flat between the lock assembly and the door edge. Your picture showing the door face looks like it's all the way toward the edge right now. The dead bolt will be even further in but probably will still work.
ScottG
Bothell Wa.
Posted: 08/10/22 08:16pm Link  |  Quote  |  Print  |  Notify Moderator
SJ-Chris wrote:
ScottG wrote:
It's a $25 item - just replace it.
Which item is $25?
A new complete door latch from TriMark is ~$150+. Are you suggesting that just a part of this latch needs to be replaced? If so, I wasn't thinking that was an option but would be good. Please elaborate. Thanks
I paid $26 for the entire assy just to get a unit key'd like my other door. Has worked perfectly for 4 years so far.
In retrospect, it probably wasn't a TM but it looks and works exactly like the one I replaced. I would buy one again.
* This post was edited 08/10/22 08:55pm by ScottG *
IAMICHABOD
Sunny So Cal
Posted: 08/10/22 11:04pm Link  |  Quote  |  Print  |  Notify Moderator
I book marked a E Bay seller a while back that sold a repair kit that may have been mentioned earlier.
Trimark Repair Kit
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
Rick Jay
Posted: 08/11/22 08:37am Link  |  Quote  |  Print  |  Notify Moderator
Trimark Repair Kit
That's it!!! Nice work! The website for the part is www.latchfix.com. There's a video which shows how to do the replacement.
It looks like it went up in price a bit....but then again, what hasn't?
Just make sure it fits the style of Tri-Mark door lock that you have on your rig. If it does, then I highly recommend this product.
SJ-Chris, looking at your pictures a bit closer, I'm 95% sure your bolt/plunger is the older pot-metal type. The pot metal is a dull gray in appearance, no shine or gloss to it. If it was the newer model, I believe it would be shinier. I believe you can also check it with a magnet. If a magnet doesn't stick to it, it's the pot metal version. For peace of mind, I'd replace it. Getting locked in OR locked out is not fun, and it happens without warning. That pot metal cracks and it "no worky no more".
Good Luck
~Rick
SJ-Chris
San Jose, Ca
Posted: 08/12/22 03:31pm Link  |  Quote  |  Print  |  Notify Moderator
After watching the video above, I went to my RV to take a look at the door latch. What I realized is that my slider bolt is NOT broken (as in the video) and therefore I didn't need a new slider bolt. The issue is that the bolt just doesn't stop extending where it should (it goes about 1/8th of an inch too far extended) and therefore when it hits the door jam it is not on the slanted part of the bolt and therefore it doesn't compress.
So I had an idea to glue in a tiny piece of metal on the bolt (in the yellow circle on the top rail) in the photo here:
After giving it plenty of time to dry I tried it out. The opening mechanism/arm immediately popped my little piece of metal out and therefore the solution didn't work. Out of a bit of annoyance/frustration, I decided to try putting a ziptie around it as someone above had mentioned. I wasn't happy with the idea is it isn't very elegant (and I don't know how long it would last for), but I tried it anyway. It does in fact hold back the bolt from extending too far.
Honestly, I was surprised I was even able to get the lock plate screwed back together and in place as I thought the large part of the ziptie would get in the way. But I was able to. And I know that if this doesn't work (or breaks), I can always remove it later. Low and behold, it works! (for now at least). I'll try this out for a few months and see if there are any issues.
Reminder: One of the reasons I'm willing to "play around" with such a solution is because my latch bolt is NOT broken and the door does allow itself to open and close even without this bandaid fix. There has never been an issue of not being able to open the door, fear of getting stuck inside/outside, etc.
If there are any updates in the future I'll let you know!
-Chris
Rick Jay
Posted: 08/12/22 04:57pm Link  |  Quote  |  Print  |  Notify Moderator
SJ-Chris,
I applaud you for your solution to prevent the slider bolt from extending all the way. I could tell from your pics that yours didn't break. However, it WILL break. And this guy named Murphy will tell you that when it does, it will be at the worst possible time. [emoticon] You've already closed the door (probably several times) with the slider bolt over-extended. That put lateral stress on that part, and might have already weakened it. That's the problem, when it breaks, there IS no warning. The door does NOT open and you're trapped...either inside or outside.
The first time this happened to our rig, I was surprised how many others had the EXACT same problem. And like I said, we pretty much babied the closing of the door...I detest door slammers! LOL Anyway, I believe, there were some folks who sent documentation to the NHTSA to see if Tri-Mark could be forced to fix this as this could conceivable be a life-threatening failure if the lock broke and there was a fire inside the RV. Perhaps a "perfect storm" of problems, but not outside the realm of possibility. We have a driver's door on our Class A, but if the fire is at the front of the rig, that door would be useless. If the main entrance door didn't open, then wifey and I have to try to squeeze our "not so skinny" butts out the emergency window in the bedroom with the requisite "fall" to the ground. LOL
Ok, just my line of thinking, but what I paid for that upgraded steel bolt and the peace of mind it provides, I felt it is well worth it. I didn't want to take any chances, and when the kit mentioned above became available, I quickly ordered it and installed it.
I'd recommend that you order it. The frustration you save will be your own! [emoticon]
Safe travels,
~Rick
SJ-Chris
San Jose, Ca
Posted: 08/12/22 05:16pm Link  |  Quote  |  Print  |  Notify Moderator
Rick Jay wrote:
SJ-Chris,
Safe travels,
~Rick
Thanks for the info/suggestion! I'm not opposed to spending money on these things as I do like everything (every light bulb in fact) to be working correctly.
It seems there is a big difference between the "pot metal" vs the "actual metal" bolts and their durability. The "pot metal" bolts are the ones that break. I haven't searched it, but I haven't heard anyone state that their "actual metal" bolt broke yet. I've also heard that the pot metal bolt is not magnetic (...side note: I find this strange....what IS pot metal???). I will likely put a magnet to mine to see if it is real metal or pot metal. If it is pot metal, I will be much more inclined to replace it as you suggest. If it is actual metal, I think I'm comfortable keeping this bolt in there. I'll let you know what my test reveals....
Happy camping!
Chris
