RV.Net Open Roads Forum: Travel Trailers: Patching an enclose underbelly
 > Patching an enclose underbelly
traildog
Pendleton, IN USA
Posted: 07/29/22 09:36am Link  |  Quote  |  Print  |  Notify Moderator
So, I pulled my rig in a massive rain storm and a few days later, I see water dripping from an opening in the underbelly material.
I'm thinking leaky plumbing so, I make a slit in the material so I could take a look. No leak so I assume it got in there from the rain.
So now I've made an unnecessary cut in my underbelly because there are
NO accessible fasteners to open it.
I've tried to you Gorilla tape to close it but it didn't stick.
Any sugestions?
2021 Coachmen Freedom Express Ultra Lite 259FKDS.
2021 Ford F-150 3.5 ECO BOOST 4:30
Cambria, California area
Posted: 07/29/22 09:48am Link  |  Quote  |  Print  |  Notify Moderator
I'd try Eternabond tape. It will stick.
TurnThePage
North ID
Posted: 07/29/22 09:53am Link  |  Quote  |  Print  |  Notify Moderator
Eternabond is ugly but it work well for that application. And it doesn't show anyway.
2015 Ram 1500
2004 Pioneer 18T6
MFL
Midwest
Posted: 07/29/22 12:03pm Link  |  Quote  |  Print  |  Notify Moderator
If you have a fiber insulation in the belly, it should be dried out/replaced. You can make a 3 sided window for a better look, and then purchase an oversized piece of coroplast to cover. Sheet metal screws will hold the cover to existing coroplast.
Jerry
ford truck guy
Pennsylvania
Posted: 07/29/22 12:17pm Link  |  Quote  |  Print  |  Notify Moderator
^^^ What Jerry said..... Dry it all out and apply Eternabond
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
klutchdust
Orange, California
Posted: 07/29/22 01:22pm Link  |  Quote  |  Print  |  Notify Moderator
What material is the underbelly made of. If metal of some sort I would pop rivet an aluminum patch .
ford truck guy
Pennsylvania
Posted: 07/29/22 01:28pm Link  |  Quote  |  Print  |  Notify Moderator
Usually it is Coroplast - - Coroplast at Lowes
Thermoguy
Graham, WA
Posted: 07/30/22 09:43am Link  |  Quote  |  Print  |  Notify Moderator
They make Coroplast tape - I haven't tried it but it should work. I have a couple cuts in mine as well. I used what I had laying around. Not great, but hasn't come undone.
stripit
Prescott
Posted: 07/30/22 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
I used to cut a three sided flap with the solid side facing forward. Made sure the opening was wide enough for my shoulders to fit up and into the bottom.Then once finished up inside to reseal the flap I bought 2 inch by 1/2 inch thick wood slat, cut that wood so one inch would lay inside the cut out and one inch would lay where the flap would be and used 1 inch screws to secure the flap back into place. I used 3 pieces of wood to secure the flap. Then used either a quality tape or ran a bead of weatherproof sealant along the slit. If and when I need to get back into that space, the screws were easy to remove and reopen the flap.I made 4 of these under my 5th wheel for repairing either plumbing or slide out rams.
Stacey Frank
2016 Tiffin Allegro Bus 40AP
2019 Tesla Model X
2015 Cadillac SRX we Tow
1991 Avanti Convertible
campermama
Here and There
Posted: 07/31/22 07:53am Link  |  Quote  |  Print  |  Notify Moderator
I used gorilla tape on mine, you just have to clean the area real good first! Works great!
2018 Dodge Ram 3500 Laramie,SRW,CTD,4x4,Long bed
2020 Jayco eagle ht 274ckds
My Adventure Blog:
https://roaddivaontheroad.blogspot.com/2020/03/getting-ready.html
