Kostyan
Baltimore, MD
I am storing my camper outside year round and noticed it excess humidity levels forming inside in warmer months. It is being parked on asphalt driveway but surrounded by heavily wooded area.
Running dehumidifier did not go to well because could not figure out how to run a discharge house to let condensate outside without cutting a hole in a camper lol
Also thinking of moving camper to a different area on my lot presently grassy area that will
Get a couple of truckloads of crushed stone or pebbles over if.
So the challenge is to protect the inside as well as the outside / underbody from excess humidity and elements.
Any input is appreciated.
2007 R-Vision Trail Cruiser by Trail Lite C21RBH
towed by 2012 BMW X5 diesel
bgum
South Louisiana
Put down a moisture barrier underneath the stone.
Gdetrailer
PA
Concrete or asphalt would be the best to park it on as long as there is a "crown" or angle that allows water run off.
Dirt/gravel is a poor choice, moisture comes right up through the ground and gravel.. Lots of vehicles rot from the underside very quickly when parked on dirt/gravel and don't get moved often..
Your over thinking this, simply open a few windows slightly (even sliding windows can be opened slightly without fear of rain getting in) which allows the air inside the RV to be exchanged with the air outside the RV.. Inside of RV will not get any wetter or damper than the air outside..
ktmrfs
Portland, Oregon
Kostyan wrote: I am storing my camper outside year round and noticed it excess humidity levels forming inside in warmer months. It is being parked on asphalt driveway but surrounded by heavily wooded area.
run the dehumidifier discharge hose into the shower basin, leave the grey tank outside drain slightly open, problem solved.
2011 Keystone Outback 295RE
eHoefler
ozark mountains
Run the A/C
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
spoon059
Just north of D.C.
ktmrfs wrote: run the dehumidifier discharge hose into the shower basin, leave the grey tank outside drain slightly open, problem solved.
And if the OP is concerned about pests flying up into the grey tank, he could leave it closed and just open it once or twice a season.
But I agree with another comment, I leave my roof vent open almost year round (has a vent cover to keep rain out) and leave one crank out window at least vented almost all year. I only close them in the spring when the pollen is ridiculous.
Our old camper (bought used) initially had a mildewy smell when it sat in storage. After we started keeping the roof and window vented open, the smell went away and never came back.
2015 Ram CTD
2015 Jayco 29QBS
prichardson
Lafayette, La
Ventilation is the key. Roof vent open with cover and a window opened. All I have is slide windows so I made this to keep weather out.
Cambria, California area
I agree with all comments regarding venting. Very important.
CarnationSailor
Cathedral City, CA
You don't need to do anything other than provide ventilation. Our 5th was stored on grass in the damp Seattle area for many years with no problem.
2015 Crossroads Rushmore Springfield
2015 Chevy Silverado 2500HD Duramax
WinMinnie02
NJ
Parked unit outside no covers except for tires exposed to sunlight. Leave roof vent crack open, run generator monthly with ac on during summer, winter remove excess snow off the roof. 20+ years no issues, replace caulk, clean it, and do maintenance DIY, easy.
