SoonDockin
Oklahoma
Love the F450 with the Arctic Fox 1140 for traveling. Just find the ride a bit rough on some of Americas moon scape of a road system. Been looking at suspension upgrades but as we are at the limit of payload, it makes sense to go with a higher payload and not worry about adding weight from new suspension.
Any one had seat of the pants experience with Liquid Springs? From what I have read, most are happy with the outcome.
2022 Ram Laramie 5500 60" CA New pic soon
2018 Arctic Fox 1140 Dry Bath
Sold 2019 Ford F450 King Ranch (was a very nice truck)
Bumpyroad
Virginia
will that add issues, require cdl etc.
bumpy
SoonDockin
Oklahoma
Well if I use a F550 hauling a truck camper, its still considered a recreational vehicle isn't it?
Southern California :(
Depends on your home state, Soon. Ask your DMV. Read their information.
Bumpyroad wrote: will that add issues, require cdl etc.
bumpy
Nope
jimh406
Western MT
If you are going F550, you might also consider a chassis cab F350 which is higher rated than the F450 pickup style and with 17s on the F350, it's probably going to be a better ride than other options. Are you running the stock suspension on your F450. My current tires ride a lot better, and I found Bilsteins shocks and are bags help. I would guess liquid springs are more similar to the air bags.
'10 Ford F-450, 6.4, 4.30, 4x4, 14,500 GVWR, '06 Host Rainer 950 DS, Torklift Talon tiedowns, Glow Steps, and Fastguns. Bilstein 4600s, Firestone Bags, Toyo M655 Gs, Curt front hitch, Energy Suspension bump stops.
NRA Life Member, CCA Life Member
SoonDockin
Oklahoma
I am running stock suspension with airbags that I am increasingly lowering. I know the tires are a big part of the rough ride but the idea on an active suspension system that can react in 40ms it will help I bet. My F450 has less than 30k miles so I bet it will still be worth close to what I paid for it. If I am buying new, I would be happier with the F550 than a F350. The turning circle of my F450 is so much nicer than F350's.
mkirsch
Rochester, NY
bumpy
Per Ford, F550 GVWR is 17,500-19,500lbs, depending on how its equipped. Well short of the 26,001lbs limit where CDL is required.
markowwes
Vegreville, Ab. Canada
We went with a F550 Super Duty with the heavy suspension pkg. to get the most GVW possible.
Added the Kelderman 4 link air ride to the rear and Kelderman air bags in the front. The package came with Rancho Shocks and an extra heavy rear torsion bar. Each wheel has a ride height automatic adjuster so the truck never changes the ride height no matter how much load you carry. The empty ride is still a little rough but not as bad as with the springs and loaded it rides very well. Total weight with the boat we are at 28,500 lbs.
![[image]](https://i.postimg.cc/Y4h73XSy/Begore-Air-lines.jpg)
![[image]](https://i.postimg.cc/pmKctz6X/Front-bags-in.jpg)
![[image]](https://i.postimg.cc/Sj7WqVyP/Empty.jpg)
SoonDockin wrote: I am running stock suspension with airbags that I am increasingly lowering. I know the tires are a big part of the rough ride but the idea on an active suspension system that can react in 40ms it will help I bet. My F450 has less than 30k miles so I bet it will still be worth close to what I paid for it. If I am buying new, I would be happier with the F550 than a F350. The turning circle of my F450 is so much nicer than F350's.
Are you sure you’re not just looking for a solution to a problem that doesn’t exist? Or just an excuse for a new truck?
Because your analysis and reasoning is off a bit.
