Baja Man
Inland Empire, CA
Hello all--
I wanted to see if anyone has a method for removing brake drum/hub bearing races from trailer brake drums using a simple shop press.
I know there are kits that use machined alum discs of various sizes to install races and seals (either with a hammer, press, and air hammer) but have never seen how to remove them using a shop press.
I know how to remove races using a brass drift and hammer. You must access race at an angle, as the race can not be hit vertically with the drift. This is what makes using a press a challenge.
So.....how can races be removed from brake drums using a shop press?
Maybe it's so simple, I can't see it or think of it!!!
Thanks!
2003 Ford F-350 XLT Super Duty, Crew Cab, V10 (6.8L); 4X2; Standard Bed; SRW; 4R100 trans
2011 Outback 250RS - Anniversary Edition
Equal-i-zer 10K
Huntindog
Phoenix AZ
As an owner of a 30 ton press, I woudn't bother. I am sure I could rig something up, but it would be much easier and faster to just hammer them out with a drift
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1860watts solar,800 AH Battleborn batterys
2020 Silverado HighCountryC CD/A 4X4 DRW
Mike134
Elgin, IL
Huntindog wrote: As an owner of a 30 ton press, I woudn't bother. I am sure I could rig something up, but it would be much easier and faster to just hammer them out with a drift
Yep you're tossing them anyway beat them out
2019 F150 4X4 1903 payload
2018 Adventurer 21RBS 7700 GVWR.
time2roll
675w Solar pictures back up
Baja Man
Inland Empire, CA
time2roll wrote: ![[image]](https://encrypted-tbn0.gstatic.com/images?q=tbn:ANd9GcQjTnu7jk3PX_f6ZnhdLI93UAAbYZ4osjduc0gxHCivfWCB-s3-PyxWN4w6brCW69FhxJA&usqp=CAU)
What did that bearing race removal bushing come from?
Custom made or ???
JRscooby
Indepmo
The artist missed the fact the shape of hub will not let anything vertical reach the race. Driving them out, always working at angle.
OP, you might cut a bar the right length to lay on the race, then push the center.
Big races, with alloy hubs, where I fear the impact might distort the hub, I have just ran a bead in center of face. The weld will pull the race, let it just slide out.
Baja Man
Inland Empire, CA
Curious, have you ever used your 30T press for such and activity?
I just may use a brass drift and hammer to remove....but I like to use the best and safest tools available when I can.
Thanks
time2roll
JRscooby wrote: The artist missed the fact the shape of hub will not let anything vertical reach the race. I agree but things can vary. I am not looking at it. Even a picture may not show well due to the angles etc. If the OP thinks there is an edge to catch then will need to make or buy the tool.
Otherwise yes I would have all six drums clear by now and pressing in the new.
QCMan
Independent Republic of Horry
How about using a puller instead of pushing it. There are a lot of pullers with adapters to hook just about anything. Some auto parts stores lend them out with a deposit.
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
Baja Man
Inland Empire, CA
QCMan wrote: How about using a puller instead of pushing it. There are a lot of pullers with adapters to hook just about anything. Some auto parts stores lend them out with a deposit.
I don't believe there is a puller made to pull races from hubs where there is no direct vertical access.....That may be the reason why they are punched out with a drift...?
