Baja Man
Inland Empire, CA
JRscooby wrote: time2roll wrote: ![[image]](https://encrypted-tbn0.gstatic.com/images?q=tbn:ANd9GcQjTnu7jk3PX_f6ZnhdLI93UAAbYZ4osjduc0gxHCivfWCB-s3-PyxWN4w6brCW69FhxJA&usqp=CAU)
The artist missed the fact the shape of hub will not let anything vertical reach the race. Driving them out, always working at angle.
OP, you might cut a bar the right length to lay on the race, then push the center.
Big races, with alloy hubs, where I fear the impact might distort the hub, I have just ran a bead in center of face. The weld will pull the race, let it just slide out.
Good idea about a bar across the race.....I'm thinking some 1/4" flat bar that is arced to fit race arc and just shy of the full width (there isn't much room between race and sides of drum....probably thousandths of an inch) of the race so doesn't scrape on sides of hub yet still fully catches race edge.
Thoughts?
2003 Ford F-350 XLT Super Duty, Crew Cab, V10 (6.8L); 4X2; Standard Bed; SRW; 4R100 trans
2011 Outback 250RS - Anniversary Edition
Equal-i-zer 10K
Microlite Mike
NW Washington State
Baja Man wrote: Hello all--
I wanted to see if anyone has a method for removing brake drum/hub bearing races from trailer brake drums using a simple shop press.
I know there are kits that use machined alum discs of various sizes to install races and seals (either with a hammer, press, and air hammer) but have never seen how to remove them using a shop press.
I know how to remove races using a brass drift and hammer. You must access race at an angle, as the race can not be hit vertically with the drift. This is what makes using a press a challenge.
So.....how can races be removed from brake drums using a shop press?
Maybe it's so simple, I can't see it or think of it!!!
Thanks!
You listed pretty much all the reasons why it's too difficult to bother.
I've been using shop presses for over six decades and I can add a couple reasons to the list:
Shop presses are usually used to store all kinds of junk when not in use or are behind junk stored in front of them.
You have to adjust press beam to the right height.
If you don't want to bend hub/drum/disc you have to find a suitable backing device.
The action of the press is usually very slow.
By the time one gets the press cleared out/off, set up, and race pressed out (different setup for front and rear races) the average person could have all the races "punched" out of all four hubs/drums/disc's and well on their way to just installing with a proper tool (kit is about $50 or less on amazon for races and seals)
Shop presses are for gears and press on axle bearings. A waste of time for wheel bearing races.
Might be useful on large truck and off road equipment hubs but usually a portable hydraulic puller kit is more practical.
"Knowledge is realizing that the street is one-way, wisdom is looking both directions anyway."
~ Albert Einstein
Vintage465
Prunedale CA.
I knock them out with a drift and freeze the new ones and install them with the same drift once they are tapped into place with a hammer. I don't use a brass drift or a brass hammer. The races are so much harder than the drift or the hammer, you'd have to really be asleep at the wheel to do any kind of damage to a race with either.
V-465
2013 GMC 2500HD Duramax Denali. 2015 CreekSide 20fq w/450 watts solar and 465 amp/hour of batteries. Retired and living the dream!
dodge guy
Bartlett IL
A hammer and a drift works great and is easier than setting it up in a press.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
eHoefler
ozark mountains
If you have a welder handy, run a bead all the way around on the race, turn it over and let cool. It will fall out, literally, it will fall out. I have built many gear boxes that have blind bearing caps, welding is the best way to remove the races with out damaging the cap.
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
Stop overthinking. Could have popped them out in the time it took to write the question.
2017 Heartland Torque T29
QCMan
Independent Republic of Horry
Maybe try this non existent tool
https://www.harborfreight.com/3-jaw-pilot-bearing-puller-4876.html?utm_source=google&utm_medium=cpc&utm_campaign=12144811130&campaignid=12144811130&utm_content=117789253198&adsetid=117789253198&product=4876&store=726&gclid=EAIaIQobChMI3K3u7uul-QIV0WxvBB28SgqQEAQYBCABEgLoVfD_BwE
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
Huntindog
Phoenix AZ
QCMan wrote: Maybe try this non existent tool
https://www.harborfreight.com/3-jaw-pilot-bearing-puller-4876.html?utm_source=google&utm_medium=cpc&utm_campaign=12144811130&campaignid=12144811130&utm_content=117789253198&adsetid=117789253198&product=4876&store=726&gclid=EAIaIQobChMI3K3u7uul-QIV0WxvBB28SgqQEAQYBCABEgLoVfD_BwE I'd rather spend the 13.00 on beer for after I finish the job using a drift... Heck, in a pinch, I have used a screwdriver.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1860watts solar,800 AH Battleborn batterys
2020 Silverado HighCountryC CD/A 4X4 DRW
Microlite Mike
NW Washington State
Huntindog wrote: QCMan wrote: Maybe try this non existent tool
Agree on the beer and using a screwdriver. Over the years I've actually found that a screwdriver actually got more "grip" on the race, depending on the hub.
Problem with this tool, and the bearing races they are supposed to pull, is that there is no room behind the race, where it is pressed into the hub' for it to grip.
The tool is for "Sleeve Type Bearings" where there is plenty of room for the 'fingers" to reach through and grip the EXPOSED surface of the sleeve.
Even if the fingers fit thorough the race (maybe the rear but good luck on the front), setting up the tool would take more time than a drift punch and hammer.
ksbowman
Kansas
I do like @eHoefler said and quick welding bead and they almost or do fall out when the weld cools and shrinks the race.
