swimmer_spe
Sudbury, Ontario, Canada
We have a 1999 trailer with a 2 way fridge. I only use it on propane setting.
Lat year, I could turn it on the night before we left, leave it set at 4, and be below freezing in the fridge. I would then turn it down to 2 for the rest of the trip and it work well to keep things between 0-5C
This year, doing that and the fridge does not seem to cool. I have to turn it to max to get it below 5C and keep it there.
I have tried to blow out the dust from the back.What should I check or other maintenance should I do before hiring a tech to fix it?
2oldman
NM
Since you've seen the back I assume there isn't any other kind of colorful deposits back there?
BobsYourUncle
Calgary Alberta Canada
Check the vent out the top and make sure there is nothing blocking it. Bird or hornet nest or ??
Also, there is a sensor on the cooling fins inside the fridge at the back. It is adjustable to tweak the temperature. Check to make sure you didn't knock it off kilter with something you put in the fridge.
Dmax/Allison
2007 Pacific Coachworks Tango 306RLSS - 32'
RV Rebuild Website
Site is live, finally launched Aug 22, 2021 @ 6:53 PM
Gjac
Milford, CT
Check the burner tube that rust from the chimney vent did not fall down and block the slots. Is the flame yellow or blue?
ktmrfs
Portland, Oregon
take off the gas orifice (usually unscrews easily) and blow it out with compressed air. and then blow out the tube to the burner. The orifice has an extremely tiny hole, easy for even a spider web to partially clog.
Then fire it back up. you should see a nice uniform blue flame.
2011 Keystone Outback 295RE
Sjm9911
New Jersey
Could also be your regulater, everything else working ok? Addtionally, as its a 2 way, maybe swap it over to the other setting to make sure that works. That will tell you if its a fuel problem or a fridge problem.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
swimmer_spe
Sjm9911 wrote: Could also be your regulater, everything else working ok? Addtionally, as its a 2 way, maybe swap it over to the other setting to make sure that works. That will tell you if its a fuel problem or a fridge problem.
Don't think it's the regulator as everything else is good.
It is a 2 way but the electric pops the breaker, so I don't use it.
Sjm9911
New Jersey
Thats not good. I would recomend burping it, but dont know for sure. If it worked on 110 then no use doing it, as it works, but may be worth a shot if you have nothing left. Some say it works. Some dont. It may be worth a try. I would leave that as a last resort. Tbh, dont know how you would burp a bigger fridge.
Sjm9911
New Jersey
https://www.rvtravel.com/does-your-refrigerator-have-indigestion-burp-that-baby/
swimmer_spe
Sjm9911 wrote: https://www.rvtravel.com/does-your-refrigerator-have-indigestion-burp-that-baby/
Thank you. I'll look into it and maybe give it a good burp.
