dougrainer
Carrolton, Texas
swimmer_spe wrote: Sjm9911 wrote: https://www.rvtravel.com/does-your-refrigerator-have-indigestion-burp-that-baby/
Thank you. I'll look into it and maybe give it a good burp.
Burping NEVER fixes a partial or completely block Cooling unit. Waste of time. Doug
Sjm9911
New Jersey
dougrainer wrote: swimmer_spe wrote: Sjm9911 wrote: https://www.rvtravel.com/does-your-refrigerator-have-indigestion-burp-that-baby/
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
Sjm9911
New Jersey
Doug, and what advice do you have have that is maybe helpful to the situation? I did say some like it and some dont? And i believe I said to do it as a last resort? At least now we know where you stand. Almost like we needed the helpful advice. Oh, no , we didnt. Lol.
BobsYourUncle
Calgary Alberta Canada
Hi Doug, I know its a long shot, but sometimes we get lucky with burping a fridge, ![smile [emoticon]](http://www.rv.net/sharedcontent/cfb/images/smile.gif)
Mine died completely one cold winter of being FT in Alberta.
I had nothing to lose, so:
I took the fridge out, rolled it end over end multiple times, waiting a few minutes between each flip, and then I reinstalled it. I gave it about 24 hours to "settle down" before running it. It worked flawlessly for years and was still working long after I sold the TT.
I know it doesn't always work, but sometimes it does. ![smile [emoticon]](http://www.rv.net/sharedcontent/cfb/images/smile.gif)
I think it was an RM2562 - 2652?
Dmax/Allison
2007 Pacific Coachworks Tango 306RLSS - 32'
RV Rebuild Website
Site is live, finally launched Aug 22, 2021 @ 6:53 PM
swimmer_spe
Sudbury, Ontario, Canada
I understand that it may or may not work. However, if after doing the other things it still acts up, doing a burp won't hurt it any worse than not burping it. Besides, this may be our last season with this RV and I'd rather fix it than not, but not spend crazy money to fix it.
dougrainer
Carrolton, Texas
Sjm9911 wrote: Doug, and what advice do you have have that is maybe helpful to the situation? I did say some like it and some dont? And i believe I said to do it as a last resort? At least now we know where you stand. Almost like we needed the helpful advice. Oh, no , we didnt. Lol.
I am just stating a FACT. After 43 years as a RV tech, I think I would know what works and what does NOT work. If a person wants to take the time to remove the refer and then spend a couple of days rotating the refer and then reinstalling. Then do it. A LOT of work for something that will not work. Years ago People with a blocked refer would burp when selling and the refer "appears" to work when they sell it, but a few days later it is blocked again and the new owner is stuck. Newbies have no idea how much RV refers cost and cost to replace a cooling unit. Blocked refers, the freezer will work, THAT is what gets buyers to think the refer is OK. Doug
ktmrfs
Portland, Oregon
before you get into "burping" or other stuff have you verified that the gas jet is not obstructed and that you get a nice blue flame on the burner?
I've found that the jet is easily obstructed by even part of a spider web or piece of dirt it is so small and a blast of air will clean it out and be back to normal.
2011 Keystone Outback 295RE
lenr
Indianapolis, IN
1999 is pretty old fridge. When you give up completely and if you can get to Indiana, check our National RV Refrigeration North of Shipshewana. They know their stuff. They rebuild units, install scratch and dent units, or install new units all at likely less money than anywhere else. They also do AC.
Sjm9911
New Jersey
dougrainer wrote: Sjm9911 wrote: Doug, and what advice do you have have that is maybe helpful to the situation? I did say some like it and some dont? And i believe I said to do it as a last resort? At least now we know where you stand. Almost like we needed the helpful advice. Oh, no , we didnt. Lol.
Ok so it works just dosen't last? Trying to read in between the lines. I dont know how it would appear to work. It works or it dosen't. I get it may not last, depends whats in the tubes blocking it. I do know with the smaller ones, people have had sucess that lasted years.
Gdetrailer
PA
Sjm9911 wrote: dougrainer wrote: Sjm9911 wrote: Doug, and what advice do you have have that is maybe helpful to the situation? I did say some like it and some dont? And i believe I said to do it as a last resort? At least now we know where you stand. Almost like we needed the helpful advice. Oh, no , we didnt. Lol.
![[image]](http://www.sherv.net/cm/emoticons/hand-gestures/facepalm-hand-gesture-smiley-emoticon.gif)
If it doesn't last or last long, did it really "make it work"?
So, one must ask themselves the question, how many times per trip am I willing to remove a 120+ lb fridge, turn it upside down, turn it back over then reinstall it and cross all your fingers and toes and hope it works again for the rest of the trip????
Really, if it is dead (IE not working properly), either do a proper repair (like a new cooling unit) or replace entire fridge.
Burping is a temporary bandaid which may last 1 hr or it may last yrs, one really does not know for sure since there is no magic window to peer in to see where the blockages are. Once you start having internal crystallization (which is what creates the blockages) the game is over, one crystal begats another and another each cycle..
Take a fridge out ONCE and I can assure you that you really will not wish to do that again.. Bigger fridges takes two people, might get away with one person on a 3 cuft ones but anything of 10 cu ft or larger you are in the 120 lb+ weight and they are insanely top heavy.
