RV.Net Open Roads Forum: Tech Issues: Norcold 12cu Drains Battery on LP
 > Norcold 12cu Drains Battery on LP
2oldman
NM
Posted: 08/01/22 04:09pm Link  |  Quote  |  Print  |  Notify Moderator
I don't have any idea why this fridge is draining your battery, but I have another suggestion. My Dometic will get reasonably cool in around 4 hours, so I pack it with cold food and turn it on at the same time. Yours may do the same.
StirCrazy
Kamloops, BC, Canada
Posted: 08/02/22 08:07am Link  |  Quote  |  Print  |  Notify Moderator
are you running the fridge on propane or electric?
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
campermama
Here and There
Posted: 08/02/22 08:23am Link  |  Quote  |  Print  |  Notify Moderator
hugsfamily wrote:
I'm not sure about a door condensation heater....how would I check and turn off if so?
Look at the schematics for the fridge. Mine has a heater/light (the light in the fridge) 5A fuse! It was killing my battery every night! I pulled the fuse, and bought a small motion sensor light ($5) at walmart and put it in the fridge. Problem solved!
Good luck!
2018 Dodge Ram 3500 Laramie,SRW,CTD,4x4,Long bed
2020 Jayco eagle ht 274ckds
My Adventure Blog:
https://roaddivaontheroad.blogspot.com/2020/03/getting-ready.html
Charlie D.
E. Texas-Orange
Posted: 08/02/22 03:37pm Link  |  Quote  |  Print  |  Notify Moderator
Op said he was on propane
Enjoying Your Freedom?
Thank A Veteran
Native Texan
2013 Prime Time Crusader 330MKS
2018 Chevy 2500 D/A Z71 4x4 Offroad
2006 Holiday Rambler Savoy 33SKT-40,000 trouble free miles-retired
2006 Chevy 2500 D/A-retired
2013 Chevy 2500 D/A-retired
StirCrazy
Posted: 08/03/22 06:35am Link  |  Quote  |  Print  |  Notify Moderator
yup, but I am wondering if it realy is.. no way it should drain a batery when its on propane in 4 hours, unless the battery is already dead.
Steve
dougrainer
Carrolton, Texas
Posted: 08/03/22 08:28am Link  |  Quote  |  Print  |  Notify Moderator
Steve
Even tho he has a 2022, that does not mean his battery is GOOD. It could be out of water(boiled dry) or partially boiled and has no reserve power. Doug
BarabooBob
Baraboo, WI
Posted: 08/03/22 05:24pm Link  |  Quote  |  Print  |  Notify Moderator
I installed a switch on my propane/CO detector to turn it off when we are not using the TT. I also installed a battery power smoke/CO detector and a battery powered lp gas detector. We also installed a switch to turn off all power to the radio because I don't need a bright blue night light to stay on all of the time.
Bob & Dawn Married 32 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
