RV.Net Open Roads Forum: Tech Issues: Cleaning the awning
 > Cleaning the awning
swimmer_spe
Sudbury, Ontario, Canada
Posted: 08/01/22 09:50pm Link  |  Quote  |  Print  |  Notify Moderator
Due to leaves being stuck to the awning, it has been stained from it. Is there a cleaner that is safe to use to remove the stain? The leaves are no longer on it, and I am diligent about not letting them stay on it.
afidel
Cleveland
Posted: 08/01/22 10:34pm Link  |  Quote  |  Print  |  Notify Moderator
Magic eraser mop heads worked well for us to clean the awning
2019 Dutchman Kodiak 293RLSL
2015 GMC 1500 Sierra 4x4 5.3 3.42 full bed
Equalizer 10k WDH
StarkNaked
West Seattle, WA
Posted: 08/01/22 10:51pm Link  |  Quote  |  Print  |  Notify Moderator
Directly from Dometic A&E manual:
Do not use strong chemicals or abrasives to clean
the awning parts as their protective surfaces can be
damaged. Do not use abrasive or corrosive cleaners,
mildew removers, or hard bristle brushes on the
awning fabric.
• Remove any cleaning solution completely from the
awning fabric. Bleach will degrade the awning fabric
if not completely rinsed off
1. Mix a cleaning solution of 1/4 cup dish soap and 1/4
cup bleach with five gallons of fresh water.
2. Open the awning.
3. Apply the cleaning solution.
4. Close the awning for five minutes, then open the
awning
5. Using clean water, completely remove the cleaning
solution from the top and bottom of the awning
fabric. Rinse thoroughly.
6. Repeat the process as necessary.
7. Verify that the awning fabric is dry before closing the
awning.
austinjenna
Columbus, Ohio
Posted: 08/02/22 05:30am Link  |  Quote  |  Print  |  Notify Moderator
Open the awning and spray it down with the hose
Spray Tilex on it and roll it up
Let it sit for about 30 minutes or so, open it up and spray it down again and it will be clean, no scrubbing needed
2010 F350 CC Lariat 4x4 Short Bed
2011 Crusader 298BDS 5th Wheel
Reese 16K
ford truck guy
Pennsylvania
Posted: 08/02/22 06:38am Link  |  Quote  |  Print  |  Notify Moderator
Yup, this is what I have found to be the easiest - -
Magic eraser head
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
Gdetrailer
PA
Posted: 08/02/22 08:46am Link  |  Quote  |  Print  |  Notify Moderator
Magic eraser head
Just be aware that just because Magic Erasers feel and act like a soft foam, they ARE an abrasive! Granted, a mild abrasive, but still can damage surfaces and material. Use with caution and care.
One should note that A&E does mention to not use abrasives..
All about Magic Eraser HERE
"Melamine foam is a porous material, which acts something like very fine sandpaper to gently remove stains. Though it feels soft on the outside, each eraser is actually uniquely abrasive and uses small air pockets in the material to lift stains when damp.
Areas to Avoid
Avoid using a Magic Eraser on polished, delicate, or easily scratched surfaces because it may end up removing the exterior finish or causing potential damage to the outer surface. Try a test patch on a less noticeable area before going to town on a larger spot.
Although versatile, you should steer clear of your car, stainless steel, glossy walls and wood, among other surfaces, when using your Magic Eraser."
ktmrfs
Portland, Oregon
Posted: 08/02/22 09:00am Link  |  Quote  |  Print  |  Notify Moderator
x2. amazing how well it will remove dirt, stains, mildew etc. it is a mild abrasive to be careful where and how you use it. I've found magic eraser also works very well on removing stain/yellowing/dirt on the vinyl/rubber trim strips on the trailer.
* This post was edited 08/02/22 09:06am by ktmrfs *
2011 Keystone Outback 295RE
ford truck guy
Pennsylvania
Posted: 08/02/22 10:03am Link  |  Quote  |  Print  |  Notify Moderator
Magic eraser head
Areas to Avoid
Totally agree... There is NO ELBOW GREASE with these... just slightly swipe across......
I found that out about 10-15 years ago on another awning... I used a small hand held pad and really put my weight into it !
Roger10378
Goodrich, MI.
Posted: 08/02/22 02:27pm Link  |  Quote  |  Print  |  Notify Moderator
I use Amazing Cleaner by Bio-Kleen. Spray it on. Wait a few minutes and rinse.
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
