Bayley
Meridian
I have a small leak on a corner seam in my black water tank on my 5th wheel.
Is this something I can repair myself with JB Weld or a similar product?
Thank in advance for your help!!
Tony
Semper Fi
Tony, Darlene & the boss Bentley!
2013 Ram CTD, Ride-Rite Air Bags, B&W Turnover Ball and Andersen "Ultimate 5th Wheel Connection".
2014 Arctic Fox 29-5K 5th wheel with Reese Airborne Pin Box.
12thgenusa
Loveland, Colorado
ABS tanks can be easily, successfully, and inexpensively plastic welded. I've had several repaired by a professional. I see Harbor Freight offers a plastic welder, but I don't know if it is a worthwhile tool or how much skill is involved.
2007 Tundra DC 4X4 5.7, Alcan custom rear springs, 2009 Cougar 245RKS, 370 watts ET solar,
Rogue MPT-3024, 440 AH GC2 bank, ProWatt 2000,100% LED lighting
time2roll
Black ABS can be repaired with a product called Plasti-Mend. If the damage is due to stress flexing on a corner consider adding some sheet ABS to stiffen the repair.
675w Solar pictures back up
midnightsadie
ohio
do what time2roll says.
Cambria, California area
Plasti-Mend is also my choice.
rhagfo
Portland, OR
12thgenusa wrote: ABS tanks can be easily, successfully, HF plastic wielder and inexpensively plastic welded. I've had several repaired by a professional. I see Harbor Freight offers a plastic welder, but I don't know if it is a worthwhile tool or how much skill is involved.
I used the HF plastic wielder with good success. I first melted the wire screening over the cleaned area to be repaired, then added repair plastic over it.
2112
rhagfo wrote: 12thgenusa wrote: ABS tanks can be easily, successfully, HF plastic wielder and inexpensively plastic welded. I've had several repaired by a professional. I see Harbor Freight offers a plastic welder, but I don't know if it is a worthwhile tool or how much skill is involved.
I used the HF plastic wielder with good success. I first melted the wire screening over the cleaned area to be repaired, then added repair plastic over it. I used one of these to repair an old lawnmower fuel tank a few years ago. It's still holding up.
2013 KZ Durango 2857
BarneyS
S.E. Lower Michigan
Moved to Tech Issues forum from DIY.
dougrainer
Carrolton, Texas
If the crack is on a bottom corner, odds are any type repair will be futile, due to the tank flexing when full and empty. But, it does not hurt to try. Make sure the area is CLEAN and DRY. Use sandpaper to rough up the ABS. Then apply the plastic glue material WITH a small piece of standard fiberglass screen material to strengthen the repair and prevent the tank from flexing. Is this a CRACK? If so, you will want to drill a small hole at the end of each end of the crack to prevent the crack from continuing. Doug
Bayley
Meridian
I'm a little confused on the type of plastic the tank is made of.
I contacted the manufacturer of my trailer and they said it was LLDPE. In my research it says LLDPE is white or yellowish in color. My tank is black in color. My guess is it is ABS....does that sound correct?
