RV.Net Open Roads Forum: Tech Issues: Weird electrical problem
 > Weird electrical problem
theoldwizard1
SE MI
Posted: 08/03/22 10:13am Link  |  Quote  |  Print  |  Notify Moderator
So I just fixed a very weird electrical problem on my daughter's family trailer. The only symptom I was originally given was the refrigerator does not work when switched to electric and there is no shore power.
Well, just as I was about to get started with my diagnostics, her husband said, "None of the lights work either !". Big clue, no power from the battery !!
So we checked the battery and it was good. No power to the 2 or 3 fuses we checked. Check the B+ wire in a couple of places underneath, GOOD ! So back to the converted/fuse panel. No obvious B+ without taking the whole fuse panel out. I studied the diagram on the cover and noticed that there was 40A fuse labeled "reverse battery protection". I pulled it out to get a good look and test with the meter. GOOD ! Plugged it back in and THE LIGHTS CAME ON !!!
enblethen
Moses Lake, WA
Posted: 08/03/22 10:17am Link  |  Quote  |  Print  |  Notify Moderator
I would recommend getting a new fuse! Or at least carry one!
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
BobsYourUncle
Calgary Alberta Canada
Posted: 08/03/22 10:31am Link  |  Quote  |  Print  |  Notify Moderator
Corroded fuse connection?
I've had fuses where I've had to clean up the contacts
Dmax/Allison
2007 Pacific Coachworks Tango 306RLSS - 32'
RV Rebuild Website
Site is live, finally launched Aug 22, 2021 @ 6:53 PM
SAR Tracker
Central Oregon
Posted: 08/03/22 10:44am Link  |  Quote  |  Print  |  Notify Moderator
Just like an old carburetor. Take it apart, look at it, don't change anything, put it back together, and it works. PFM. Pure Friggin Magic!
Rusty & Cheryl
2011 F250 2WD 6.2L Gasser
2008 Weekend Warrior FB2100
"Common sense is in spite of, not the result of, education" - Victor Hugo (1802-1885)
Cambria, California area
Posted: 08/03/22 10:54am Link  |  Quote  |  Print  |  Notify Moderator
I agree with enblethen…new fuse and a spare plus clean the connectors.
theoldwizard1
SE MI
Posted: 08/03/22 05:05pm Link  |  Quote  |  Print  |  Notify Moderator
Well stocked on fuses !
theoldwizard1
SE MI
Posted: 08/03/22 05:07pm Link  |  Quote  |  Print  |  Notify Moderator
Nothing obvious, but yes !
Removing and reinstalling the fuse actually makes tiny scratches.
afidel
Cleveland
Posted: 08/04/22 08:05am Link  |  Quote  |  Print  |  Notify Moderator
I'd recommend deoxit or similar to clean the contacts and then electrical/dielectric grease.
2019 Dutchman Kodiak 293RLSL
2015 GMC 1500 Sierra 4x4 5.3 3.42 full bed
Equalizer 10k WDH
pianotuna
Regina, SK, Canada
Posted: 08/04/22 09:31am Link  |  Quote  |  Print  |  Notify Moderator
Consider treating it with deoxit?
Regards, Don
