RV.Net Open Roads Forum: Zone 2 ac putting out heat,ie. COOL on.
 > Zone 2 ac putting out heat,ie. COOL on.
captron33
usa
Posted: 08/03/22 01:19pm Link  |  Quote  |  Print  |  Notify Moderator
Any fix for that problem? Duo therm. By domedic.
* This post was edited 08/03/22 01:28pm by captron33 *
dougrainer
Carrolton, Texas
Posted: 08/03/22 03:05pm Link  |  Quote  |  Print  |  Notify Moderator
Need more info, but if you have the 5 button wall tstat, the most common cause is the Reversing valve has failed or there is NO power to the reversing valve. Dometic changed this function on the 12 button CCC2 and the default when the valve fails is to always cool. Doug
siggyd777
Northern Illinois
Posted: 08/03/22 03:14pm Link  |  Quote  |  Print  |  Notify Moderator
If all your settings are correct, then the AC/Heatpump solenoid COIL is defective. It's an easy fix if you are electricly savy.
I had the same problem on my 2005 Kountry Star.
See if you can find a used or new coil on ebay.
Siggy
Happy Trails
Siggy & Ursula
2011 Dutch Star 4020,ISL 400,Compr.brake,FTL XCR,IFS
Allison MH3000
2015 Jeep Cherokee,4x4 Active Drive II,V6 , Brake Buddy,Roadmaster Sterling,
Camping since 1975 Pop-Up,1986 22Ft.TT,1999 Gas MH,2005 KSDP,
2011 DSDP,FMCA 368283
dougrainer
Carrolton, Texas
Posted: 08/03/22 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
9. REVERSING VALVE
The reversing valve is the heart of a heat pump. It changes
the direction of the refrigerant flow through the coils, and
changes the system from cooling to heating.
The reversing valveĆ­s solenoid can be energized in either the
heat or cool mode of operation. Duo-Therm roof top heat
pumps have the solenoid energized in the cool mode.
One method of checking the reversing valve is to feel the
refrigerant line at the top of the inside coil. In the COOL
mode, this line will be cool to the touch. In the heat mode
the line will be warm or hot to the touch. If you do not feel a cold line in the cooling mode, the direction of flow is not
correct.
Check the solenoid coil for ohms continuity. An open circuit (no continuity) shows the solenoid is defective and must
be replaced.
dougrainer
Carrolton, Texas
Posted: 08/03/22 05:45pm Link  |  Quote  |  Print  |  Notify Moderator
https://www.boatandrvaccessories.com/pro........DOlotPJHSwOFl50ApTlTdTimoJwaAsDqEALw_wcB
There used to be 2 coils Dometic used, but this is the only one I can find. Doug
oldave
Tx
Posted: 08/03/22 08:13pm Link  |  Quote  |  Print  |  Notify Moderator
He has an 06 Travel Supreme which I believe has a 5 button thermostat unless it's
all been changed.
captron33
usa
Posted: 08/03/22 09:42pm Link  |  Quote  |  Print  |  Notify Moderator
Yes i have the 5 button.
Thanks Doug!
captron33
usa
Posted: 08/04/22 12:00am Link  |  Quote  |  Print  |  Notify Moderator
So if iget that coil and install it the problem shoild be fixed!
captron33
usa
Posted: 08/05/22 11:08pm Link  |  Quote  |  Print  |  Notify Moderator
I ordered the part Doug said to get.now to find someone to install it.
