RV.Net Open Roads Forum: Travel Trailers: Jacking For Tire Change
 > Jacking For Tire Change
Page of 7
ford truck guy
Pennsylvania
Posted: 08/17/22 06:02am Link  |  Quote  |  Print  |  Notify Moderator
Grit dog wrote:
JRscooby wrote:
I don't know where you guys get the magic floor jacks that don't move. Just for snots and grins I just put a tape on 1 of mine (standard 7000 lb capacity that I load if I know I'm going to need a jack, or grab if I need to lift a car in the drive) I put the wheels against the wall and measured to center of pad. 5 inches. Jacked to top, 13 inches.
I'm with Scooby here. GDE, I am genuinely interested in seeing a pic of your rolling floor jack that doesn't just have a single pivot on the arm, which by default as the angle changes, the jacking point gets closer to the rear part of the jack.
Hard to believe 5 pages about changing a flat tire, but I guess that happens when people have magic floor jacks!
I am NO SUPERIOR mechanic but......
I always thought that the wheels on the floor jack were there so the jack COULD MOVE when lifting to keep the weight closer to the center point of the jack????????? If they did NOT move, ALL of the weight being lifted would be at the far end of the jack...
Think Forklifts.... A 15,000# lift is rated to lift 15,000#.. AT THE CENTER POINT OF THE FORKS.... IF you try to lift 15,000 on the tips of the forks, you will be greatly disappointed
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
MFL
Midwest
Posted: 08/17/22 07:13am Link  |  Quote  |  Print  |  Notify Moderator
ford truck guy said..."I am NO SUPERIOR mechanic but......"
You obviously understand the working of a floor jack, so SUPERIOR mechanic to GDE, as an example.
Jerry
wanderingbob
monticeeo, fla
Posted: 08/17/22 09:44am Link  |  Quote  |  Print  |  Notify Moderator
Back aways Grit Dog said a man should be able to pick out a good lookin girl at 100 yards . At 78 years old I can see good enuff to pick em out but ain't noway that I could pick em up unless they weigh less than 30 lbs !
PButler96
Midwest
Posted: 08/18/22 02:00am Link  |  Quote  |  Print  |  Notify Moderator
After reading through 7 pages could someone tell me the size and type of jack I need to lift a pallet of Tylenol?
I have a burn barrel in my yard.
klutchdust
Orange, California
Posted: 08/18/22 10:40am Link  |  Quote  |  Print  |  Notify Moderator
Experience proves what works. The lack of that is very clear here.
Like Mike Tyson said "everyone has a plan until you get punched in the mouth"
Mike134
Elgin, IL
Posted: 08/18/22 01:04pm Link  |  Quote  |  Print  |  Notify Moderator
bump
2019 F150 4X4 1903 payload
2018 Adventurer 21RBS 7700 GVWR.
Texas Nomad
Posted: 08/25/22 09:28am Link  |  Quote  |  Print  |  Notify Moderator
Interesting discussion! Everyone stay tuned because on October 1st I'm going to start a brand new thread titled: Just Had a Flat ... What's the Best Way to Jack Up My Trailer? [emoticon][emoticon][emoticon]
Fisherman
Angus, Ontario, Canada
Posted: 08/25/22 04:17pm Link  |  Quote  |  Print  |  Notify Moderator
[emoticon] Don't forget the right sized socket.
JIMNLIN
Oklahoma
Posted: 08/29/22 12:01pm Link  |  Quote  |  Print  |  Notify Moderator
Jack up the trailer just to change one flat tire or all of them ??? This otta' be could.
StirCrazy
Kamloops, BC, Canada
Posted: 08/30/22 08:10am Link  |  Quote  |  Print  |  Notify Moderator
JRscooby wrote:
B-n-B wrote:
This exact jack would not get under a flat tire on my trailer, at least not under the spring perch. I carry a small floor jack with a 1x6 if needed.
Do you also carry the important part needed to safely use that jack? By that I mean a floor.
With no load on it, run the jack up. Notice the lift pad goes up in a arc? Normal lifting, the pad stays in contact with lifting point be cause the jack rolls under the load. If the wheels are setting on soft or rough surface the pad must slide on you lift point. At least you're not under when it drops.
if your jacking the axel just enough to take the tire off the ground its no issue. I just did all my wheel berrings yesterday and jacked under the axel on gravel just enough that the tire would rotate, but I could see what you are talking about if you have to change a flat.
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
Page of 7
