RV.Net Open Roads Forum: Travel Trailers: Jacking For Tire Change
 > Jacking For Tire Change
Page of 7
ROBERTSUNRUS
Salem, Oregon
Posted: 08/03/22 10:35pm Link  |  Quote  |  Print  |  Notify Moderator
[emoticon] Hi, "Trailer Aid Plus"
"> Bob ">
2005 Airstream Safari 25-B
2000 Lincoln Navigator
2014 F-150 Ecoboost
Equal-i-zer
Yamaha 2400
PButler96
Midwest
Posted: 08/04/22 01:20am Link  |  Quote  |  Print  |  Notify Moderator
Grit dog wrote:
wanderingbob wrote:
Never jack
Really? Why?
He read it on the interwebs?
I have a burn barrel in my yard.
Tvov
CT
Posted: 08/04/22 04:14am Link  |  Quote  |  Print  |  Notify Moderator
I've done both - jacked where the axle U-bolts are and run one tire up onto a ramp. Both worked, did not damage the trailer.
2021 F150 2.7
JRscooby
Indepmo
Posted: 08/04/22 04:37am Link  |  Quote  |  Print  |  Notify Moderator
Changing a tire? Do it on a nice day in driveway first. Dark, rain, with traffic going by is not the time to go to school.
Ramp under other tire might work, but will need to be pretty steep with some trailers.
Now the most risky time is when you get wheel off, discover you need up just little more to get the other on. I pull the flat on a ramp until center of axle is at normal height. This way, takes much less jacking. Flat off ramp, slide ramp out, wheel off, then back on.
Flan
NE
Posted: 08/04/22 06:00am Link  |  Quote  |  Print  |  Notify Moderator
I slide my jack in between the 2 tires and jack up on the triangle shape equalizer.
Heartland Prowler 27LX
19 Ram CTD 2500
ford truck guy
Pennsylvania
Posted: 08/04/22 06:35am Link  |  Quote  |  Print  |  Notify Moderator
When jacking, I USED to place it under the spring perch... virtually no chance of damage that way....
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
wanderingbob
monticeeo, fla
Posted: 08/04/22 06:53am Link  |  Quote  |  Print  |  Notify Moderator
With a "trailer aide ' type device you can have the flat off the ground in the the time it takes to place 'trailer aide " at the tire and pull forwards or backwards . Back 15 years or so before the Goodyear trailer tire recall my wife and I changed several flats each week during our delivery schedule . Are best all time record was eight minutes between blow out and back on the road . NEVER JACK !
Fisherman
Angus, Ontario, Canada
Posted: 08/04/22 07:10am Link  |  Quote  |  Print  |  Notify Moderator
I look at it this way, if the trailer was meant to be rolled up on a lazy trailer aide, then why did they put 2 axles on it with 2 tires? To support the weight, period. Now you're going to shift all that weight to one tire with the suspension completely twisted to achieve that. Don't be lazy, use the appropriate jack.
Posted: 08/04/22 08:37am Link  |  Quote  |  Print  |  Notify Moderator
Oh... now I understand. Because rolling up a ramp with the good wheel is a quick method, it makes other methods unacceptable...
Totally makes sense [emoticon]
2017 Heartland Torque T29
theoldwizard1
SE MI
Posted: 08/04/22 08:38am Link  |  Quote  |  Print  |  Notify Moderator
Ramp/"trailer aid" looks to be a good solution.
I would still carry Powerbuilt 3 Ton, Bottle Jack and Jack Stands All-in-1
Page of 7
