RV.Net Open Roads Forum: Tow Vehicles: 2012 Yukon not seeing trailer connected
Search only in Tow Vehicles
 > 2012 Yukon not seeing trailer connected
gmcman
va
Posted: 08/03/22 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
I have the factory integrated brake controller,(JL-1) this is the 1st time it's being used as I had to connect the red wires to the studs.
Fuses are good, I have 12V at the studs.
I have 12V at the brake control relay or module located above the spare tire.
The blue wire is good between the module/relay to the 7-pin, and both sides of the 7-pin are clean.
No stored codes.
Trailer works on another vehicle, and the Yukon still doesn't work on a 2nd trailer.
I have also tried a new GM gain switch and module, still no change.
No error messages, but the Yukon still won't recognize when a trailer is connected.
Curious if anyone has dealt with this.
blt2ski
Kirkland, Wa
Posted: 08/03/22 09:22pm Link  |  Quote  |  Print  |  Notify Moderator
Has the Yukon pulled a trailer before? If not, my last 3-4 GMs have a big fuse that needs to be added to a fuse box in the engine compartment, drivers side.
Marty
2014 Chevy 1500 Dual cab 4x4
gmcman
va
Posted: 08/03/22 09:32pm Link  |  Quote  |  Print  |  Notify Moderator
I don't know if the previous owner did, but it looked like none of the 12V leads were hooked up.
The two big fuses for the studs are in place, and I have 12V to each of the studs.
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 08/04/22 06:51am Link  |  Quote  |  Print  |  Notify Moderator
Are the brakes on the trailer electric drum or electric over hydraulic disc??
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
gmcman
va
Posted: 08/09/22 12:34am Link  |  Quote  |  Print  |  Notify Moderator
Brakes are electric drum.
