RV.Net Open Roads Forum: Kwikee series 32 step replacement Motor & Gearbox
 > Kwikee series 32 step replacement Motor & Gearbox
Paul Hopwood
Central Texas
Posted: 08/04/22 07:47am Link  |  Quote  |  Print  |  Notify Moderator
I have series 32 double steps on our Motorhome and need to replace the Gearbox & Motor with the updated equipment.can anyone tell me which Motor and Gearbox I need?
Just when i think I have it figured out I read they are for triple steps would that still work on mine?
Thank you.
dougrainer
Carrolton, Texas
Posted: 08/04/22 07:58am Link  |  Quote  |  Print  |  Notify Moderator
https://store.lci1.com/kwikee-step-motor-conversion-kit-for-a-linkage-379145
This is the kit from the OEM supplier. But, you can find it cheaper. You HAVE to replace the door magnetic or pin switch when installing this kit. Failure to do that will result in step operating in reverse. The kit comes with the new Magnet for the door. Doug
https://www.etrailer.com/Accessories-and-Parts/Kwikee/LC29VR.html
fyrflie
Martinez, CA. USA
Posted: 08/04/22 09:31am Link  |  Quote  |  Print  |  Notify Moderator
Click
Maybe this will work.
* This post was edited 08/04/22 04:33pm by an administrator/moderator *
Paul Hopwood
Central Texas
Posted: 08/04/22 10:38am Link  |  Quote  |  Print  |  Notify Moderator
Thank you Both!
Bruce Brown
Northern NY
Posted: 08/04/22 04:29pm Link  |  Quote  |  Print  |  Notify Moderator
Depending on exactly what you need, get the number off the motor, chances are you can buy it on-line for far less than buying one labeled for an RV.
Normally its not the entire gearbox, rather the plastic part in the gear motor.
We needed a new one about a year ago, taking the number off the motor I was able,to buy it for 1/10th the price of buying the exact same part that said motorhome on it.
* This post was edited 08/05/22 06:00am by Bruce Brown *
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
katysdad
Virginia
Posted: 08/04/22 07:36pm Link  |  Quote  |  Print  |  Notify Moderator
If all you may need is the motor I used to get them from Orielly auto parts. If I remember they were Ford/Mercury window motors for 2 door applications. I cant remember if they were right or left side. Significantly cheaper than from kwikee.
Dodge Ram 3500 DRW Diesel
Paul Hopwood
Central Texas
Posted: 08/06/22 02:12pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, unfortunately I am unable to read the sticker, and the numbers cast into them don't seem to match any.
I think i found one that will work.
Will they stop trying to retrack when it gets seated even if there more pull from the motor?
RLS7201
Posted: 08/07/22 03:24pm Link  |  Quote  |  Print  |  Notify Moderator
If I'm reading you correctly, the motor keeps running, going thump thump, when the steps reach the end of travel.
That would be the 3 cushings in the motor gear box, that have collapsed.
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
Yankee Clipper
Cairo, GA
Posted: 08/08/22 08:26am Link  |  Quote  |  Print  |  Notify Moderator
If I recall correctly, the motor used by Kwikee was a dead-on match to the driver's side power window motor for a 1996 Taurus. It was a gamble for $30, but, get this, it worked too well and over-torqued the gearbox. When I opened the gearbox, all the teeth fell on my bench. Had to buy an integrated motor-gearbox assembly anyway. Sometimes the shortcut works...
Later that year, 2018, Hurricane Michael dropped two pines on that Coachmen and totalled it. That ended the warranty on the new motor-gearbox.
Yankee Clipper
2014 Winnebago Sightseer 33C on Ford F53 6.8l V10
2014 Honda CRV 4 down toad/Roadmaster Falcon2 with EvenBrake
TireMinder TPMS, Duke the overgrown Boxer mascot/lousy watch dog
Rosey the minidachshund resident Princess-in-Chief
