RV.Net Open Roads Forum: Tech Issues: Gauges are not working
 > Gauges are not working
backdoc3
Fort Dodge
Posted: 08/04/22 11:40am Link  |  Quote  |  Print  |  Notify Moderator
I have a 2008 Four Winds Mandalay. We recently left our campsite to go home and have no gauges. The warning light was for low air pressure and the RV rode like a school bus. No RPM, no speedometer, nothing. Frieghtliner chassis. Any ideas?????
Steve Schwendemann
Horsedoc
Dixie --- N. Georgia
Posted: 08/04/22 11:57am Link  |  Quote  |  Print  |  Notify Moderator
Our precious coach (Freightliner chassis) did that twice. Scared me. I turned it off and shut everything down, waited a few minutes and restarted.
The coach had been setting for a few weeks both times
afidel
Cleveland
Posted: 08/04/22 06:02pm Link  |  Quote  |  Print  |  Notify Moderator
My first guess would be a ground issue, but that's pure guesswork based on watching lots of automotive troubleshooting videos.
2019 Dutchman Kodiak 293RLSL
2015 GMC 1500 Sierra 4x4 5.3 3.42 full bed
Equalizer 10k WDH
pianotuna
Regina, SK, Canada
Posted: 08/04/22 10:02pm Link  |  Quote  |  Print  |  Notify Moderator
check the grounds
Regards, Don
Posted: 08/05/22 04:48am Link  |  Quote  |  Print  |  Notify Moderator
I'll support the Ground as 1st guess.. #2 and 3 are a Fuse (Marked gauges likely 5 or 10 amp) and a plug fell out...
True story: Radio in my motor home was very "Bump Senistive" the radio clearly worked but no sound from the speakers.
Well after many hours of pulling hair out.. Found the idiot did not plug the plug in all the way.. Pressed on it and click-click 100% operation. (the clicks were the plug's latches latching).
backdoc3
Fort Dodge
Posted: 08/05/22 07:35am Link  |  Quote  |  Print  |  Notify Moderator
Thank to everyone who has taken the time to reply. Still no resolution but if it is a grounding issue where do I look? BTW my radio also works, but no sound.....
afidel
Cleveland
Posted: 08/05/22 07:24pm Link  |  Quote  |  Print  |  Notify Moderator
I've found the wiring diagram for the chassis but it doesn't have physical locations for any of the connectors or grounds. Not sure if there's an equivalent of service data for RVs that would include that or not, might call a mobile tech or RV service manager and ask.
pianotuna
Regina, SK, Canada
Posted: 08/06/22 09:54am Link  |  Quote  |  Print  |  Notify Moderator
afidel Start at the dash fuse box. Use a flashlight to attempt to follow the wires. It will not be fun.
time2roll
Posted: 08/06/22 10:36am Link  |  Quote  |  Print  |  Notify Moderator
Start ripping it apart. I guaranty it will be the last place you look.
675w Solar pictures back up
