RV.Net Open Roads Forum: Fifth-Wheels: New to 5th wheels
 > New to 5th wheels
t-smith
SW, OH
Posted: 08/04/22 07:05pm Link  |  Quote  |  Print  |  Notify Moderator
So After a lot of deliberation, I’ve settled on a Shasta Phoenix 355FBX. I’ve had travel trailers for the last 12 years. This will be my first 5ver. I’m having the Reese Goosebox 16k installed as it will be easiest since my other trailers (horse, equipment) are also gooseneck.
What else should I be thinking about when switching to the new platform?
For instance, I already have X-chocks, so those should transfer.
Additional stabilizers needed? (Has 4 point elec leveling system)
This will have 2 sewer outlets. Should they just be Y connected together?
Thanks!
2018 F250 CCLB
2012 Grey Wolf 28BH
stickdog
Somewhere, USA
Posted: 08/04/22 07:55pm Link  |  Quote  |  Print  |  Notify Moderator
The Y will keep things simple.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
BB_TX
McKinney, Texas
Posted: 08/04/22 08:48pm Link  |  Quote  |  Print  |  Notify Moderator
Do you have wheel chocks also? The X chocks are for stabilization, not for keeping the trailer from rolling. Read the instructions.
t-smith
SW, OH
Posted: 08/04/22 08:50pm Link  |  Quote  |  Print  |  Notify Moderator
Of course! First thing that goes down before unhooking. X-chocks on after my TT is leveled.
ford truck guy
Pennsylvania
Posted: 08/05/22 08:02am Link  |  Quote  |  Print  |  Notify Moderator
My son in law has an RV with 2 sewer outlets.. He has 2 sets of everything running to a "Y" then into the sewer...
Depending on the RV, you MAY need stabilization in the front, a set of JT Strongarms are awesome ! - JT's
OR - Morryde also
IF the rear leveling jacks are too far forward, you MAY need something closer to the rear?? Morryde X brace
OR add 2 bolt on scissor jacks and this -
Morryde again
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
Fresno Tundra Driver
Fresno,Ca. USA
Posted: 08/05/22 03:41pm Link  |  Quote  |  Print  |  Notify Moderator
Think about adding Sumo springs in place of the bump stops. Easy to do it yourself. It really helped smooth out the ride while towing my fifth wheel.
E.Lee Galik
t-smith
SW, OH
Posted: 08/05/22 04:36pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks. Air bags installed thankfully - so no worries there
fj12ryder
Platte City, MO
Posted: 08/06/22 06:43am Link  |  Quote  |  Print  |  Notify Moderator
With the 4 point leveling system, you'll likely need some thing to help at the rear. The Morryde X Brace will work, but if you don't have a hitch, try the Valterra stabilizer. It looks cheesy, but it really works. We have one for our 17,000 lb. toyhauler and it keeps the rear pretty darned solid.
Howard and Peggy
"Don't Panic"
RickLight
Washington
Posted: 08/07/22 05:35pm Link  |  Quote  |  Print  |  Notify Moderator
I use my sewer Y with FHU but just move the hose at a dump. Black, then bath gray. The kitchen tank goes last and is plenty soapy to not need much rinsing afterwards.
Rick,
2019 Grand Design Reflection 150 273MK
2015 Ford F350 CC SB Lariat Powerstroke
PullRite Superglide
 > New to 5th wheels
