RV.Net Open Roads Forum: Fifth-Wheels: tire wrench
 > tire wrench
BB_TX
McKinney, Texas
Posted: 08/08/22 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
Or simply try to slip on both SAE and metric sockets to see which fits better.
JRscooby
Indepmo
Posted: 08/09/22 04:29am Link  |  Quote  |  Print  |  Notify Moderator
And I suggest once you know the size, instead of removing from your set to carry you get that size, a long breaker bar, and extension for socket and if needed the bar.
BTW, I use extension to hold socket in line with stud.
redhooker
Posted: 08/15/22 05:27pm Link  |  Quote  |  Print  |  Notify Moderator
I carry a collapsible 4 way lug wrench. It has a button that allows it to scissor spin down to a small package. 3 sizes AND it has a 1/2 inch socket adaptor for a deep well socket if you need a thin wall for a tight aluminum wheel. Best of all worlds you can find on amazon for about $40.
Tinyandthegang
Mt. Shasta, Ca.
Posted: 08/20/22 12:33pm Link  |  Quote  |  Print  |  Notify Moderator
I would test that wrench in the driveway before putting much faith in it. They are very weak where they fold.
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 08/20/22 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
Deep Well Socket, 6 inch extension and breaker bar, works for both TV & RV
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
Tvov
CT
Posted: 08/21/22 04:58am Link  |  Quote  |  Print  |  Notify Moderator
Happycamper30 wrote:
I have a 2008 Cruiser 5th wheel, does anyone know what size the lug nuts are and where is the wrench to change my flat tire?
Thank you.
"Where is the wrench"...? Are you asking where the "factory" lug nut wrench is on your camper? Because there is none. It is not like a car (or truck) that comes with a jack and lug nut wrench behind the seat... TT or Fivers don't come with those, you have to get your own.
If you are lucky, your tow vehicle's wrench and jack will work with your camper. Otherwise you need to buy what you need. If you are having trouble figuring out sizes, try an auto parts store (NAPA or other) on a slow day and ask the counter people for help. To be polite, assuming they go out and help figure what you need, you should buy the parts / equipment from them.
Do you have a local repair garage that knows you? Pull in there, they will probably be glad to help figure out what you need.
2021 F150 2.7
redhooker
Posted: 08/21/22 06:43am Link  |  Quote  |  Print  |  Notify Moderator
Been using it for five years no issue, I have multiple trailers so it is the best tool for my use. The connection is in the center and is quite strong.
ford truck guy
Pennsylvania
Posted: 08/21/22 02:46pm Link  |  Quote  |  Print  |  Notify Moderator
I have a nylon coated deep dish socket with a Milwaukee M-18 @ 3/4” ,drive impact
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
Allworth
Orlando, FL
Posted: 08/22/22 12:31pm Link  |  Quote  |  Print  |  Notify Moderator
My son got me the cheapest battery powered impact wrench that Harbor Freight sells.
keep the battery in the charger, plugged in in the basement when in camp and it is always ready.
(Works on the stabilizer jacks, too.)
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
2008 Titanium 30E35SA; EZ-Lube axles; wet bolts; spring hanger gussetts; BFG Commercial TAs
"Real Jeeps have round headlights"
 > tire wrench
