RV.Net Open Roads Forum: Class C Motorhomes: Stalls While Driving
 > Stalls While Driving
Posted: 08/05/22 09:14am Link  |  Quote  |  Print  |  Notify Moderator
Assuming your engine is fuel injected (460s got EFI in the late 80s and it was relatively higher pressure, for the time, not like early low pressure throttle body injected engines).
This alone should all but eliminate vapor lock.
However, there are several other things that could present as the same symtoms.
First though, if it is vapor lock, I believe the boiling point of high octane is a bit higher than low octane gas, so cheap experiment to try a tank of premium, or even premium pure gas.
But I still think vapor lock is about impossible with a 40-50psi fuel system.
Other things:
Old van, old fuel pump? One the fuel pump is heat soaked and that is exaggerated by high ambient temps and also by low fuel levels (less fuel cooling if less volume), it could be losing pressure or shorting out due to heat soak (expansion).
Similarly, it possible for the same to happen to the fuel pump relay although less likely, I think?
Also possible that the ECM is shorting out and losing contact when very heat soaked (had this happen to a boat ECM once).
Is the fuel pump still running (you can hear it) after it stalls?
If not, then I'd lean towards ECM/relay issues, but on a 30 year old vehicle, new relays, fuel pump and filter is not actually throwing parts at a problem, its preventative maintenance.
Bottom line, less likely to be vapor lock on an EFI system than it is to be some other issue.
2017 Heartland Torque T29
theoldwizard1
SE MI
Posted: 08/05/22 09:15am Link  |  Quote  |  Print  |  Notify Moderator
BarryG20 wrote:
Fuel injected engines can still experience vapor lock but it is much less prevalent than on carbureted vehicles.
Never heard of this ! Typical fuel pressure on an inject engine is 3 or 4 times that of a old fashioned mechanical pump.
rjstractor
Maple Valley, WA
Posted: 08/05/22 09:53am Link  |  Quote  |  Print  |  Notify Moderator
Before throwing parts at it, some basic troubleshooting is in order. If you are able to duplicate the problem (often the hardest part), when it stalls carefully give it a brief shot of starting fluid into the intake to see if it starts or pops. Some will say you should never use starting fluid on a fuel injected engine, but a very brief shot for diagnostic purposes should not be harmful. If there's still no action, it's likely an ignition problem.
SOMOS
Los Angeles
Posted: 08/05/22 11:32am Link  |  Quote  |  Print  |  Notify Moderator
Thank you all for the great advice! Incredibly helpful! Scottiemom... you gave me hope! Yay!!!!
Thanks again! I will post updates after some repairs.
In gratitude,
@JoeSilvaWrites
WinMinnie02
NJ
Posted: 08/05/22 11:34am Link  |  Quote  |  Print  |  Notify Moderator
Good luck OP and congrats on your RV. Tell us how you fixed it and GoRV!
BarryG20
Castle Rock, Colorado
Posted: 08/05/22 11:49am Link  |  Quote  |  Print  |  Notify Moderator
While it can happen it certainly isn't a normal thing especially these days in fact it is virtually unheard of in todays modern injected vehicles but remember this is a 30 year old injection system on a rv no less that probably lagged behind the rest of the auto industry technology to begin with, it is probably nothing more than throttle body injection which was in its heyday at that time period and those ran on about 9psi or so unlike todays that are running 40-60psi.
I know this is apples to bananas but my 01 diesel fuel injection pressure was 4-5k no rail now they are pushing 27+K rail pressure. Injectors and injector technology have come a very long way since 1991.
2016 Jayco 28.5 RLTS
Krusty
Calgary, Alberta,Canada
Posted: 08/05/22 12:17pm Link  |  Quote  |  Print  |  Notify Moderator
91 E-350 would have port type injection system that ran 30-45 psi fuel pressure. 99.9% chance it is a weak fuel pump causing your issue. Very common on those, especially in hot weather. Replace your fuel pump and the inline filter too. I'm sure it will solve your problem.
Krusty
92 F-250 4x4 460 5spd 4.10LS Prodigy
97 Rustler RT190
EU2000i
Garmin
Tom_Anderson
NorCal
Posted: 08/05/22 01:35pm Link  |  Quote  |  Print  |  Notify Moderator
Before you replace the fuel pump. hook up a fuel pressure gauge and see what the fuel pressure does when it stalls. If it's staying at 45PSI, the pump isn't your problem.
ernie1
Sacramento,California,USA
Posted: 08/05/22 01:44pm Link  |  Quote  |  Print  |  Notify Moderator
I had a 1989 E350 years ago that was fuel injected and had similar issues. It started with, while driving in hot weather, I would get a very strong gasoline smell. It was so strong that you were sure there was a lot of leaking fuel. I would stop and check everything and not find. any leaking gas! But when I unscrewed the gas cap, I got a loud whoosh of presure coming out of the filler neck. After that and not again until I would be driving in hot weather would it occur. Eventually things started getting really hot under the vehicle the propane tank pressure relief valve would shoot off a loud burst of gas for about 30 seconds and then eventually things would cool off and be okay. On this same trip, the ac condensing line came loose and shot all of the freon out. eventually the engine started acting up and I lost some power so that I could only go. 45 mph.
It turns out that one of the problems was the catalytic which had come apart and was partially plugged up which was causing the converter to overheat and run red hot.
I was told by a Ford mechanic that the 2 oxygen sensors were faulty and causing the failure of the catalytic converter which caused things around the vicinity to also overheat and fail.
bobndot
Posted: 08/07/22 10:19am Link  |  Quote  |  Print  |  Notify Moderator
x2
