paries
utah
Hello,
i have a 2019 fleetwood pacearrow 36u
the two outlets one the main bedroom slideout have quit working.
I have checked each plug and the look ok
I have checked the breakers
i have check all GFI plugs.
We are getting ready to leave for a 1000 mile trip and i am really concerned about an electrical fire.
I realize that this is a pretty specific model question, but maybe someone has some info or ideas that may help me trouble shoot this
Thanks
rk911
DuPage County
frustrating, i know. i'll bet there's another GFCI outlet that you've either forgotten about or it's not in an obvious place. i had the same thing happen in a previous motorhome and finally found the tripped outlet in a basement storage compartment.
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'23 Jeep Wrangler JL
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
midnightsadie
ohio
double check the gfi that you know about, some times they don,t reset, or could be a bad gfi.got a meter ? also check your breakers .
USAFBILL
Alabama
Slideouts are noted for causing electrical issues.....check under the slide if you can see any wiring.
2003 Cougar 285EFS
2000 Chev 2500 Ex Cab
Bruce Brown
Northern NY
Another vote for the GFI. We lost 1/2 our outlets once, everything seemed good. On the advice of an electric guy here (thanks Larry!) we changed the GFI and everything's been good since. That was years ago, so obviously it was the cause.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
CA Traveler
The Western States
Buy a 3 light household plug checker with a button to check GFCI and check all RV plugs. Are the 3 lights on and does the button trip the GFCI plug?
You could have a loose wire or bad GFCI.
FULLY flip all CBs off and then on.
2014 Grand Cherokee Overland
Bob
paries
utah
So if i had a bad GFI, would the NOT be working. I have plugged something into both GFI's and they both work
rgatijnet1
Check the circuit breakers on your INVERTER itself. This would be in a basement compartment. Mine had two circuit breakers and when when one of them tripped, I would always lose some outlets. These are not to be confused with any circuit breakers in your electrical panel. They are right on the front of your inverter.
CA Traveler
The Western States
paries wrote: So if i had a bad GFI, would the NOT be working. I have plugged something into both GFI's and they both work Most liklely OK, but the load side wiring could be loose.
I'd plug in a 3 light tester with a GFCI trip button and make sure they actually trip.
About $20.
Have you tested ALL of the other plugs to determine that it is only those 3 that don't work?
paries
utah
yeah, all the plugs in the rig appear to work except the two in the slideout.
The slide out is solid underneath, so there is nothing to look at there.
I pulled out the two outlets and they appear to be connected ok, and there is only one 14/2 coming to both, so i am afraid I may have to get under the bed. (That should be fun).
