RV.Net Open Roads Forum: jackknife sofa removal
Bandaid
Holcomb, New York USA
Posted: 08/05/22 11:44am Link  |  Quote  |  Print  |  Notify Moderator
I am getting ready to have optional factory theater seat recliners installed in my 2021 Sunseeker Classic, by Forest River. Presently, the unit has a jackknife sofa where the theater seats will be. I want to remove the sofa before the new seats are installed, mostly to save installation time, as the installing dealer get $174 per hour shop rate.
I am a hand guy, with lots of tools and automotive experience, so I am pretty sure I can handle removal of the old sofa. However, has anyone else with a class C done a removal like this? Is the sofa taken out in one piece, or is best to disassemble it and remove it in pieces?
I do plan to advertise the couch and recover some money, as it is in excellent condition.
Thanks,
Bandaid
2oldman
NM
Posted: 08/05/22 12:46pm Link  |  Quote  |  Print  |  Notify Moderator
I removed the bed first. Pretty heavy.
JimJohnson
Texas Hill Country
Posted: 08/05/22 01:28pm Link  |  Quote  |  Print  |  Notify Moderator
I haven't personally removed our jack knife sofa, but our RV repair guy recently did to replace the slide-out floor under it. The frame is likely bolted to both the floor and the wall. That's likely not a big deal to move. But unless your first name is Samson, I agree that taking the jack knifed bed out in sections is going to be much easer than trying to wrestle the whole thing through the RV entrance door.
Cptnvideo
Arizona - most of the time
Posted: 08/05/22 01:31pm Link  |  Quote  |  Print  |  Notify Moderator
We had a 2019 Forester 27' Class C. I removed the U shaped dinette and installed a power reclining theater seat myself. The theater seat just fit thru the door with the seat backs and arm rest covers removed.
Bill & Linda
Arizona
2019 Dodge Laramie 3500 dually 4x4 diesel
Hensley Trailer Saver BD5 hitch
2022 Grand Design Solitude 378MBS
1600 watts solar, 3kw inverter/charger, 3 206AH LiFePo4 batteries
opnspaces
San Diego Ca
Posted: 08/05/22 04:21pm Link  |  Quote  |  Print  |  Notify Moderator
Never removed one but I've read about it more than once here.
Take the back off and out the door first. Then take the seat out.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
garym114
Bluff Dale, Texas
Posted: 08/05/22 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
Removed it from my Class A
Remove all the bolts holding down the frame, using a lever raise the frame starting at one end and support the frame using 2x4 blocks, one in back and one in front. Repeat for middle and other end.
Make longer 2x4 blocks the length of each frame, front to back. Lever the frame up so that it is supported on two high 2x4.
The frame is now up and above the bolts coming out of the floor so the sofa can slide out without lifting.
Slide out so it can be lifted and lift so it stands on one end. Then out the door on end.
AllegroD
Outdare
Posted: 08/08/22 04:59pm Link  |  Quote  |  Print  |  Notify Moderator
DP Class A. Two people. Unbolted from floor. Pulled it out. Opened the bed so the bed was flat. Right out the door.
