RV.Net Open Roads Forum: Our most used adapters when towing with an Electric Vehicle.
 > Our most used adapters when towing with an Electric Vehicle.
Reisender
NA
Posted: 08/06/22 11:48am Link  |  Print  |  Notify Moderator
Hi folks. I had to take a pic for the Facebook EV towing group so I thought I would post it on the forums as well although I don't think there are many on this forum towing with an EV. This is more specifically aimed at those EV’s using the Tesla mobile charge cable but since any EV can use a tesla mobile cable (with a J1772 adapter) I’ll direct this at all EV’s. I know the Ford Lightning dudes are getting the Tesla mcu for their travel kits. And remember, ask permission, follow the rules and follow the one thing at a time plugged in etiquette.
Anyway. If you are just starting your EV tow vehicle journey wether that be with a Rivian, a Lightning or a Tesla these are the adaptors we have used most often over the last 12000 kilometres of towing with an EV using our Tesla EVSE seen in the picture. Obviously this has to do with charging from an AC source like houses, campgrounds etc. DC fast charging is another topic.
So From left to right.
14-50 Good for max 32 amps at 240 volts on a 50 amp pedestal.
5-15. Good for 12 amps at 120 volts on a standard 15 amp receptacle.
5-20. Good for 16 amps at 120 volts on a standard 20 receptacle (getting really common on pedestals and it seems to be getting common in driveways as well.
TT30. Good enough for 24 amps at 120 volt on a standard 30 amp RV pedestal.
Keep in mind that if the line voltage sags the EVSE (charge cable) will detect this and lower the charge by either 25 or 50 percent depending how low it is.
By far and away the most useful was the TT30 as 50 amp receptacles are rare up here in the places we camp.
And of course the best way is still at a DC fast charger.
Hope this is useful for newbies towing with an EV. There are other dongle adaptors available if you have access to welder plugs etc but these were our most commonly used.
Darryl&Rita
Grande Prairie, Alberta
Posted: 08/06/22 01:11pm Link  |  Print  |  Notify Moderator
Thanks for the post. Helps everyone that reads it, whether they admit it, or not.
***UPDATE 2006 3500 SRW MegaCab pulling a 2007 fleetwood 5'er
qtla9111
Monterrey, Mexico
Posted: 08/06/22 01:15pm Link  |  Print  |  Notify Moderator
Very nice setup. I bet it's fun to tow with. SLDS
2005 Dodge Durango Hemi
2008 Funfinder 230DS
Living and Boondocking Mexico Blog
Southern California :(
Posted: 08/06/22 01:30pm Link  |  Print  |  Notify Moderator
Thank you for posting. It’s the future IMO.
midnightsadie
ohio
Posted: 08/06/22 04:22pm Link  |  Print  |  Notify Moderator
looks great I,m 76 wish I was young enough to give that rig a try. never cared for camp grounds .
pianotuna
Regina, SK, Canada
Posted: 08/06/22 06:36pm Link  |  Print  |  Notify Moderator
ty Reisender
Regards, Don
Fulltimers
Anywhere, USA
Posted: 08/06/22 09:02pm Link  |  Print  |  Notify Moderator
Well at least you got a place to hang out in while you are waiting for it to charge.
Fulltimers
Fulltimers Weblog
2003 Rexhall Aerbus 3550BSL
W-22 Workhorse
2005 Saturn Vue (Mr. Toad)
3.5L V6 Automatic
Sjm9911
New Jersey
Posted: 08/06/22 10:01pm Link  |  Print  |  Notify Moderator
First thoughtwas thank god the parking lot was empty! Lol. Have fun. Didn't know anyone could use the tesla chargers. You camper is nice, cute almost. At the campgrounds, what do you usally plus in for the car and camper? Just curious.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
Reisender
NA
Posted: 08/06/22 10:16pm Link  |  Print  |  Notify Moderator
Hi SJM. To clarify, tesla EVSE’s can be used with any EV with the use of an adapter. But Tesla superchargers can only be used by Teslas.
I’m not sure I understood your second question but I’ll give it a shot. At campgrounds (with services) we rent 30 amp sites as our trailer is a 30 amp trailer. We also charge our car at those sites if required. However we obviously don’t plug in both at the same time.
Hope that helps.
Posted: 08/07/22 07:51am Link  |  Print  |  Notify Moderator
The advice I give RVers is to cary a FULL SET of adapters so you can do whatever you need Looks like you are doing precisely that.
