RV.Net Open Roads Forum: Tech Issues: toilet
 > toilet
hogbob
S.F CA.
Posted: 08/07/22 06:57pm Link  |  Quote  |  Print  |  Notify Moderator
Hello
MY toilet will not hold water, First it was a slow leak but now it drains fast. Thanks for any help. Kenny
bob213
Fresno, CA
Posted: 08/07/22 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
Clean the seal and lube it with plumbers silicone grease. (nothing petroleum based!) If that doesn't work a new seal is usually not hard to install depending on what toilet you have.
craig7h
Branson MO area
Posted: 08/08/22 03:18am Link  |  Quote  |  Print  |  Notify Moderator
I have found that the grove that seats the piece that opens and closes will get filled with TP. I have taken a cloths hanger wire and cleaned out the grove. Along with lubing the seal check out the grove.
Good Luck
Itasca Meridian SE 36g
Road Master Tow Dolly
Posted: 08/08/22 06:44am Link  |  Quote  |  Print  |  Notify Moderator
There are two styles of toilet. One has a "Ball" shaped Dump valve and the other a Gate valve.
The Ball Valve types come with a tool to clean the seal.. I've never actually used it but did clean by other means..
The other (Flat gate valve) ( I do not recall a tool. but again cleaning may help.
valhalla360
No paticular place.
Posted: 08/08/22 07:00am Link  |  Quote  |  Print  |  Notify Moderator
As mentioned, we need to know the style of valve.
One other thing not mentioned is to look for mineral deposits on the valve. Both styles rely on a smooth plastic against the rubber seal. If you get mineral built up, that can cause it not to seal.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
campermama
Here and There
Posted: 08/08/22 07:51am Link  |  Quote  |  Print  |  Notify Moderator
If it has the black rubber gasket at the opening just replace it! It takes less than 5 mins. you can get it on Amazon cheap!
2018 Dodge Ram 3500 Laramie,SRW,CTD,4x4,Long bed
2020 Jayco eagle ht 274ckds
My Adventure Blog:
https://roaddivaontheroad.blogspot.com/2020/03/getting-ready.html
Southern California :(
Posted: 08/08/22 10:50am Link  |  Quote  |  Print  |  Notify Moderator
The seal is easy to replace but try plumbers' grease first.
hogbob
S.F CA.
Posted: 08/08/22 10:57am Link  |  Quote  |  Print  |  Notify Moderator
Hello
I have the ball type can I change the seal from the top ? Thanks Kenny
JKJavelin
Milwaukee, WI
Posted: 08/08/22 11:54am Link  |  Quote  |  Print  |  Notify Moderator
I have the Thetford Style II,with the ball type gate. It's been leaking through for the last couple of years, so I finally changed the seal after watching a couple of YouTube videos on how to do it. Very simple. One guy coated it with plumber's grease, so I did that too. It was good for about 2 weeks, then started to leak through again. WTF!! It seems that the real reason is that the ball isn't quite rotating fully closed,so yesterday I sprayed silicone on everything I could see where it pivots and moves and it seems to come to a more solid stop upon release of the pedal now. We'll see how long it lasts. This wastes too much water when dry camping. I'm getting ready to switch to a Dometic!
JK
2018 Ram 3500 Laramie Cummins 6.7
2016 Open Range RF316RLS
Titan Disc Brakes
Trailair pinbox
Morryde SRE-4000 w/ wetbolt kit
Demco Autoslide
570 watts of Solar
2017- 21 Nights
2018- 75 Nights
2019- 138 Nights
2020- 72 Nights
2021- 122 Nights
2022- 127 Nights
Posted: 08/08/22 11:57am Link  |  Quote  |  Print  |  Notify Moderator
You should definitely check the grove! Lol
 > toilet
