hogbob
S.F CA.
Hello
MY toilet will not hold water, First it was a slow leak but now it drains fast. Thanks for any help. Kenny
bob213
Fresno, CA
Clean the seal and lube it with plumbers silicone grease. (nothing petroleum based!) If that doesn't work a new seal is usually not hard to install depending on what toilet you have.
craig7h
Branson MO area
I have found that the grove that seats the piece that opens and closes will get filled with TP. I have taken a cloths hanger wire and cleaned out the grove. Along with lubing the seal check out the grove.
Good Luck
Itasca Meridian SE 36g
Road Master Tow Dolly
There are two styles of toilet. One has a "Ball" shaped Dump valve and the other a Gate valve.
The Ball Valve types come with a tool to clean the seal.. I've never actually used it but did clean by other means..
The other (Flat gate valve) ( I do not recall a tool. but again cleaning may help.
valhalla360
No paticular place.
As mentioned, we need to know the style of valve.
One other thing not mentioned is to look for mineral deposits on the valve. Both styles rely on a smooth plastic against the rubber seal. If you get mineral built up, that can cause it not to seal.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
campermama
Here and There
If it has the black rubber gasket at the opening just replace it! It takes less than 5 mins. you can get it on Amazon cheap!
2018 Dodge Ram 3500 Laramie,SRW,CTD,4x4,Long bed
2020 Jayco eagle ht 274ckds
My Adventure Blog:
https://roaddivaontheroad.blogspot.com/2020/03/getting-ready.html
Southern California :(
The seal is easy to replace but try plumbers' grease first.
hogbob
S.F CA.
Hello
I have the ball type can I change the seal from the top ? Thanks Kenny
JKJavelin
Milwaukee, WI
I have the Thetford Style II,with the ball type gate. It's been leaking through for the last couple of years, so I finally changed the seal after watching a couple of YouTube videos on how to do it. Very simple. One guy coated it with plumber's grease, so I did that too. It was good for about 2 weeks, then started to leak through again. WTF!! It seems that the real reason is that the ball isn't quite rotating fully closed,so yesterday I sprayed silicone on everything I could see where it pivots and moves and it seems to come to a more solid stop upon release of the pedal now. We'll see how long it lasts. This wastes too much water when dry camping. I'm getting ready to switch to a Dometic!
JK
2018 Ram 3500 Laramie Cummins 6.7
2016 Open Range RF316RLS
Titan Disc Brakes
Trailair pinbox
Morryde SRE-4000 w/ wetbolt kit
Demco Autoslide
570 watts of Solar
2017-2022 555 Nights
2023- 75 Nights
You should definitely check the grove! Lol
