RV.Net Open Roads Forum: Fifth-Wheels: Camper Jack
 > Camper Jack
Happycamper30
Wisconsin
Posted: 08/08/22 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
I want to use my hydraulic floor jack to change my 5th wheel tire, but the floor jack won't go high enough, the soil is soft sand, it's like I need to extend it a little to reach, any Ideas?
Thank you.
rk911
DuPage County
Posted: 08/08/22 06:23pm Link  |  Quote  |  Print  |  Notify Moderator
how about putting the jack on a jack pad..or two?
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
Tennessee
Posted: 08/08/22 08:05pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from ATC
JIMNLIN
Oklahoma
Posted: 08/08/22 08:31pm Link  |  Quote  |  Print  |  Notify Moderator
when changing a tire on my trailers with leaf spring suspensions in soft dirt/sand I use a 12 ton shorty hyd jack under the axle tube next to the U bolt. Simply raise one end of the axle enough to do the change.The jack has a 10" X 10" wide base for side of the road work. The jack stays in my truck when on the road.
If I'm on concrete by my garage I use my floor jack raising one end of a axle enough to make the change.
A floor jack can weigh 80-90 lbs and gonna' be a bit heavy for lifting it off the ground under a trailer.
Some folks like to pull one tire up on a ramp hopefully raising the flat tire off the ground enough to make the change.
Tvov
CT
Posted: 08/09/22 05:01am Link  |  Quote  |  Print  |  Notify Moderator
I have used my leveling boards as a base for a jack. Also I have large wood blocks, 4x4 up to 8x8, that can act as a spacer if the jack doesn't go high enough. Sometimes just a couple short pieces of 2x4 will do the job.
I have also used "jackstands" when needed - lift up the trailer, put jackstands in appropriate places to hold it up, reset the jack and maybe add a wood block to lift the trailer higher. Wood blocks can take the place of jackstands - depending on the situation, sometimes they work better.
Usual warnings apply about working on soft ground with improvised materials.
2021 F150 2.7
valhalla360
No paticular place.
Posted: 08/09/22 06:13am Link  |  Quote  |  Print  |  Notify Moderator
We have a small 2.5ton floor jack.
Just put one of the 2x8 leveling boards under the jack then lift on the spring perch...problem solved.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
JRscooby
Indepmo
Posted: 08/09/22 06:16am Link  |  Quote  |  Print  |  Notify Moderator
I have a 5 inch high block that replaces the lift pad of my floor jack. (fits in the hole, so can't slide) I have put a block on top of jack, but that can get pretty sketchy, pretty fast. I have also put a floor jack on top of plank, (actually a steel plate on top of railroad ties) then backed vehicle over it.
I have a hard time standing under the idea a floor jack without enough lift to get the tire off the ground. Are you running 24.5 wheels?
austinjenna
Columbus, Ohio
Posted: 08/09/22 07:00am Link  |  Quote  |  Print  |  Notify Moderator
Get yourself a Traileraid
Link
2010 F350 CC Lariat 4x4 Short Bed
2011 Crusader 298BDS 5th Wheel
Reese 16K
Cummins12V98
on the road
Posted: 08/09/22 07:13am Link  |  Quote  |  Print  |  Notify Moderator
Link
You beat me to it!
I have changed tires and done suspension work on a heavy DRV with the safe dependable TrailerAid Plus.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
way2roll
Wilmington NC
Posted: 08/09/22 07:32am Link  |  Quote  |  Print  |  Notify Moderator
Link
These are cool but it should be noted they won't work with independent suspension.
 > Camper Jack
