RV.Net Open Roads Forum: Tech Issues: Repaired Spring Hanger Brackets: Now What?
 > Repaired Spring Hanger Brackets: Now What?
CavalierTwo
Arizona
Posted: 08/10/22 02:33pm Link  |  Quote  |  Print  |  Notify Moderator
First Post On RV.Net.
I recently returned from a round trip to Alaska. Driving 11,444 miles on some of the worst roads in Canada and Alaska. Due to road heaves (from freezing & thawing constantly) creates a real road hazard. I had both rear axle spring hangers break, then replaced and welded. The bummer of it was, I had to have it done a second time. The second time I had reinforcements installed. So 1 1/2" tubing was welded from hanger to hanger on both axles on my 2017 Reflection 26RL 5th wheel.
Now my question: Should I have an inspection on the entire frame, suspension & axle to see if there is other damage?
theoldwizard1
SE MI
Posted: 08/10/22 02:36pm Link  |  Quote  |  Print  |  Notify Moderator
What vehicle, including age ? What load ?
bgum
South Louisiana
Posted: 08/10/22 02:46pm Link  |  Quote  |  Print  |  Notify Moderator
Welcome to the forum.
Sounds like some of those heaves snuck up on you and you didn't have time to slow up.
CavalierTwo
Arizona
Posted: 08/10/22 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
My Tow vehicle is 2015 F250 Powerstroke. My load is around 10K.
And yes those heaves do sneak up rather quickly.
RAS43
Littleton,CO
Posted: 08/10/22 03:32pm Link  |  Quote  |  Print  |  Notify Moderator
Yes,
I would suggest you find a commercial vehicle repair shop and have them inspect everything and then have the alignment checked/aligned. It is worth the cost IMO.
valhalla360
No paticular place.
Posted: 08/10/22 04:05pm Link  |  Quote  |  Print  |  Notify Moderator
Probably worth it if there were multiple issues and had to re-repair some of the fixes.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
CavalierTwo
Arizona
Posted: 08/10/22 05:13pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks all for your input. I'll be looking up suspension specialist to get it checked out.
Thanks Again.
BarneyS
S.E. Lower Michigan
Posted: 08/10/22 05:31pm Link  |  Quote  |  Print  |  Notify Moderator
Moved to Tech Issues forum from Towing.
Not towing now.
Cambria, California area
Posted: 08/10/22 05:48pm Link  |  Quote  |  Print  |  Notify Moderator
Peace of mind is important to me. I’d get the inspection!
pianotuna
Regina, SK, Canada
Posted: 08/10/22 10:27pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
I had springs fixed. The shop did not do an alignment. Now I need new tires.
Regards, Don
