RV.Net Open Roads Forum: Tech Issues: Repaired Spring Hanger Brackets: Now What?
 > Repaired Spring Hanger Brackets: Now What?
CavalierTwo
Arizona
Posted: 08/10/22 02:33pm Link  |  Quote  |  Print  |  Notify Moderator
First Post On RV.Net.
I recently returned from a round trip to Alaska. Driving 11,444 miles on some of the worst roads in Canada and Alaska. Due to road heaves (from freezing & thawing constantly) creates a real road hazard. I had both rear axle spring hangers break, then replaced and welded. The bummer of it was, I had to have it done a second time. The second time I had reinforcements installed. So 1 1/2" tubing was welded from hanger to hanger on both axles on my 2017 Reflection 26RL 5th wheel.
Now my question: Should I have an inspection on the entire frame, suspension & axle to see if there is other damage?
theoldwizard1
SE MI
Posted: 08/10/22 02:36pm Link  |  Quote  |  Print  |  Notify Moderator
What vehicle, including age ? What load ?
bgum
South Louisiana
Posted: 08/10/22 02:46pm Link  |  Quote  |  Print  |  Notify Moderator
Welcome to the forum.
Sounds like some of those heaves snuck up on you and you didn't have time to slow up.
CavalierTwo
Arizona
Posted: 08/10/22 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
My Tow vehicle is 2015 F250 Powerstroke. My load is around 10K.
And yes those heaves do sneak up rather quickly.
RAS43
Littleton,CO
Posted: 08/10/22 03:32pm Link  |  Quote  |  Print  |  Notify Moderator
Yes,
I would suggest you find a commercial vehicle repair shop and have them inspect everything and then have the alignment checked/aligned. It is worth the cost IMO.
valhalla360
No paticular place.
Posted: 08/10/22 04:05pm Link  |  Quote  |  Print  |  Notify Moderator
Probably worth it if there were multiple issues and had to re-repair some of the fixes.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
CavalierTwo
Arizona
Posted: 08/10/22 05:13pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks all for your input. I'll be looking up suspension specialist to get it checked out.
Thanks Again.
BarneyS
S.E. Lower Michigan
Posted: 08/10/22 05:31pm Link  |  Quote  |  Print  |  Notify Moderator
Moved to Tech Issues forum from Towing.
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
Southern California :(
Posted: 08/10/22 05:48pm Link  |  Quote  |  Print  |  Notify Moderator
Peace of mind is important to me. I’d get the inspection!
pianotuna
Regina, SK, Canada
Posted: 08/10/22 10:27pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
I had springs fixed. The shop did not do an alignment. Now I need new tires.
Regards, Don
