RV.Net Open Roads Forum: Tech Issues: Refrigerator is dead
 > Refrigerator is dead
jornvango
Full-time RVer
Posted: 08/10/22 11:37pm Link  |  Quote  |  Print  |  Notify Moderator
We have a 2009 Casita trailer with original Dometic fridge. We're full-timers and typically boondock so the fridge uses propane and 12V. Today, out of nowhere, the fridge went dead. The "ON/OFF" button doesn't do a thing. I figure it may be time for a new fridge looking at the age, but, as these things usually break in the worst possible location, I'd like to see if I can get it going again as we're currently in the middle-of-nowhere Alaska for the summer and are not going back to the lower 48 until the end of September and there's no RV repair shop in hundreds of miles here.
Anyone have any troubleshooting steps I can try? I already checked the 15AMP fuse and it's good (that would have been too easy a fix!).
Thanks!
MitchF150
Puyallup, WA
Posted: 08/10/22 11:55pm Link  |  Quote  |  Print  |  Notify Moderator
So does that mean you are not getting a flame on the burner? No spark ignitor or anything?
Could be the main control board... But, seeing where you are, you aren't gonna get one from Amazon anytime soon I'd think?
No idea on your trailer or model of Dometic fridge and what they came with, but does it have a 120v option?
You would need a generator to test that, so if you don't have one or 120v nearby to at least test it, no real idea...
Good luck! Mitch
ItsyRV
Lost on the Blue Ridge Parkway
Posted: 08/11/22 05:07am Link  |  Quote  |  Print  |  Notify Moderator
I would start with attempting to jump the "ON/OFF" button.
1994 Itasca SunDancer 21RB - Chevy G-30 chassis.
SoonDockin
Oklahoma
Posted: 08/11/22 05:28am Link  |  Quote  |  Print  |  Notify Moderator
Check that 12v is making it to the back of the fridge. I once had an issue with power not making it from the fuse to the fridge. I just ran temporary wires until I was able to fix it.
2022 Ram Laramie 5500 60" CA New pic soon
2018 Arctic Fox 1140 Dry Bath
Sold 2019 Ford F450 King Ranch (was a very nice truck)
Roger10378
Goodrich, MI.
Posted: 08/11/22 06:07am Link  |  Quote  |  Print  |  Notify Moderator
You checked the fuse. There are probably more than one fuse, one on the board and one in your 12 volt panel. Which did you test and were you testing for continuity of the fuse or 12 volts at the output of the fuse?
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
nickthehunter
Southgate, MI
Posted: 08/11/22 06:28am Link  |  Quote  |  Print  |  Notify Moderator
Is there a light inside the fridge? Does the light come on?
midnightsadie
ohio
Posted: 08/11/22 07:48am Link  |  Quote  |  Print  |  Notify Moderator
PULL that fuse get get oxidzed . start at the source batt good etc.
agesilaus
North Florida
Posted: 08/11/22 07:54am Link  |  Quote  |  Print  |  Notify Moderator
I suspect the board died but don't know much about Dometic fridges. BUT I suggest you search YouTube for "Dometic refrigerator ZZZZ troubleshooting" where ZZZZ is the model. Lots of very helpful material up there. Don't give up on this one until you check the prices on a new one.
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
Superbumper
dougrainer
Carrolton, Texas
Posted: 08/11/22 08:31am Link  |  Quote  |  Print  |  Notify Moderator
REALLY need Model number. But, the FIRST thing to check is the Overtemp disc on the side of the flue metal cover. Some have a reset button and some do NOT. But it is very simple to take the 2 wires and jump together. Do this and then see if the refer comes ON. This disc kills ALL 12 volt power to the refer. Doug
theoldwizard1
SE MI
Posted: 08/11/22 09:04am Link  |  Quote  |  Print  |  Notify Moderator
midnightsadie wrote:
PULL that fuse They get oxidzed . start at the source batt good etc.
Just had that happen ! Plus fuse for inspection. GOOD ! Re-inserted and it works.
When chasing these kinds of problems an incandescent (not LED) test light is better than a meter.
