RV.Net Open Roads Forum: How to keep outdoor refrigerator door open
 > How to keep outdoor refrigerator door open
alesis
Detroit area
Posted: 08/11/22 08:59am Link  |  Quote  |  Print  |  Notify Moderator
Hey y’all-
So I’ve been looking for a product for the outside “dorm” fridge to keep the door cracked open during storage.
I see lots of option for the interior ones, but none for the small outside one. Mine doesn’t have a latch, it’s just one where you pull on a side handle to open and close.
So far I’ve just been putting a dish towel between the frame and door but I’m thinking there’s gotta be a better way?
Jerry
TV : 2021 Ford F-150 3.5 Ecoboost Max Tow
TT : 2015 Crossroads Sunset Trail Reserve 32BH
Equal-I-Zer hitch system
http://community.webshots.com/user/detroitfd
CA Traveler
The Western States
Posted: 08/11/22 09:59am Link  |  Quote  |  Print  |  Notify Moderator
There are many types of latches to keep a door closed or open like a eye hook or stop latch. Google is your friend.
But a wash cloth etc is OK.
2014 Grand Cherokee Overland
Bob
bukhrn
Lanexa, Va
Posted: 08/11/22 10:40am Link  |  Quote  |  Print  |  Notify Moderator
if what you do works, I'd stick with it.
2007 Forester 2941DS
2014 Ford Focus
dalenoel
S.E. Michigan
Posted: 08/11/22 11:32am Link  |  Quote  |  Print  |  Notify Moderator
I have a dorm freezer in the motorhome and use a towel when in storage or not being used.
03 Monaco Neptune 36PBD DP - 18 Focus Toad
Wife, myself, and Oreo the Malshi
WNYBob
Tonawanda, NY
Posted: 08/11/22 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
I use a pool Noodle split in half, and slid over an edge of the refer.
Posted: 08/11/22 01:25pm Link  |  Quote  |  Print  |  Notify Moderator
We’re you hoping that there was something far more innovative and simple than the dish rag you use?
2017 Heartland Torque T29
Posted: 08/11/22 03:07pm Link  |  Quote  |  Print  |  Notify Moderator
Agreed. There are many options that's likely one of the best.
Another is this. if it is inside a copartment you can cut a piece of wood to "Slide" under the door (Cut it in a "U" shape)
The door fits in the "U" and the wood either side of it both holds it open (By "Banging" gently against the frame) and prevents it from opening too far (Tight fit it) I forget how I did mine.
Southern California :(
Posted: 08/11/22 04:30pm Link  |  Quote  |  Print  |  Notify Moderator
Once the fridge is dried out, why keep it open?
alesis
Detroit area
Posted: 08/11/22 05:16pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the ideas guys. The wood “u” may be the best.
Though the towel works, I was hoping there was something made so when moving from storage to the house I didn’t have to open the outdoor kitchen and close the fridge door fully. Not a huge deal but it would eliminate a step.
Thanks!
alesis
Detroit area
Posted: 08/11/22 05:17pm Link  |  Quote  |  Print  |  Notify Moderator
I did google it and found nothing, hence why I asked here. As I said, there is no latch, it’s just a pressure open/close. Thanks
