RV.Net Open Roads Forum: Any issues having slides on both sides?
 > Any issues having slides on both sides?
Page of 5
ktmrfs
Portland, Oregon
Posted: 08/14/22 10:42am Link  |  Quote  |  Print  |  Notify Moderator
audiocam wrote:
We're looking at buying a new or slightly used TT. Is there any issues with RV's slides on both sides?
My wife thinks they may limit us because some parks may have restrictions on slides on both sides.
Do multiple slide owners have any insights?
Cheers, Scott
We have an outback with slides on both sides. There have been a few sites where we needed to be careful on placement to get both slides open but never a spot where we couldn't. Now that said our trailer is 35ft long so there are campgrounds we can't get into, older FS etc and many of those would have been an issue with opposing slides.
I have never been to a park that had restrictions on opposing slides.
2011 Keystone Outback 295RE
RedRollingRoadblock
Oregon
Posted: 08/14/22 12:53pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Bounder 34T with opposing slides in the front and bed slide on the right side. Never have we been to park that we couldn't open them all, real close due to trees but knowing how much they extend before setup helps.
When the DD used to live at one place we could put out the two on the right and have room to function very well as couple of her kids would come sleep in the motorhome. When stopping for a quick lunch if I could park where slide on one side could open it was great. If not we could make do. Last two times we were at Wildlife Safari with the four grands we stopped near the elephant enclosure, opened one slide and had a nice lunch.
4x4van
California
Posted: 08/16/22 11:56am Link  |  Quote  |  Print  |  Notify Moderator
As others have said, it's generally not a problem with slides on both sides; very few sites (if any) are that narrow to cause an issue. However, keep in mind that a passenger-side slide intrudes into your camping area.
We don't stop playing because we grow old...We grow old because we stop playing!
2004 Itasca Sunrise M-30W
Carson enclosed ATV Trailer
-'85 ATC250R, '12 Husky TE310, '20 CanAm X3 X rs Turbo RR
Zieman Jetski Trailer
-'96 GTi, '96 Waveblaster II
valhalla360
No paticular place.
Posted: 08/16/22 12:19pm Link  |  Quote  |  Print  |  Notify Moderator
True and depending on how the awning is mounted, may make the awning virtually useless.
- Many mount it to the main RV box, so it's mostly shading the slide out and eats up shaded space outside.
- Other designs mount it to the slide, so the slide doesn't eat up your shade.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
willald
NC
Posted: 08/17/22 02:19pm Link  |  Quote  |  Print  |  Notify Moderator
Last two rigs I've owned have had slide outs on both sides. Never has been a problem in terms of fitting in campsites, although you do have to keep in mind where your slides are when backing (or pulling) in, and where various things are on your site (like trees) that could get in the way.
Only concern I'd have with opposing slides would be 2 things:
1. Try and find out how tight it is inside the trailer when all slide on both sides are in. Can you still walk through it? Would that be a problem for you if could not? I guess with a towed RV that may not be an issue as much as it would be with a motorized, but is still something to consider.
2. For slideouts on the curb side (and this is a big one for me), how much will the slideouts cut in on your 'camping' space under the awning? For me personally, I don't want any RV where the slideout on the curb side cuts into your space under the awning. We tend to spend a lot of time outside when camping, and I like having as much shaded under awning space as I can get. I don't want a slideout cutting into that space, but thats just me.
Will and Cheryl
2021 Newmar Baystar 3014 on F53 (7.3 V8) Chassis ("Brook")
2018 Jeep Wrangler JK ("Wilbur")
ford truck guy
Pennsylvania
Posted: 08/17/22 02:46pm Link  |  Quote  |  Print  |  Notify Moderator
our 5 slides RV has never had an issue getting into the sites that we booked .... I LOVE the extra room inside, and the slides on the curb side really do not get in the way as I place my mat in front of the 1st one since that is where my awning is....
BUT, we do NOT boondock, or stay at Walmart
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
StirCrazy
Kamloops, BC, Canada
Posted: 08/22/22 09:03am Link  |  Quote  |  Print  |  Notify Moderator
see and thats what I was talking about. the back half of the camp site is cut off, this may or may not be an issue depending on how you camp. if you go to big resorts and spend a lot of time indoors with ac running then no issues, if you are in forested sites you are at the mercy of the shape of the campground and slides on that side are taking away about a 3rd of your site, or more depending on the shape.
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
ford truck guy
Pennsylvania
Posted: 08/22/22 09:15am Link  |  Quote  |  Print  |  Notify Moderator
It does NOT cut off the back 3rd... That is just not under the awning.. we set up camp and have never not been able to use that " ground" near the rear slides...
Just like anything else, IF you wanna find an issue with something, you probably will.... If you wanna adapt to something, you probably will . .
willald
NC
Posted: 08/22/22 01:18pm Link  |  Quote  |  Print  |  Notify Moderator
...Just like anything else, IF you wanna find an issue with something, you probably will.... If you wanna adapt to something, you probably will . .
...And that right there sums up probably 90% of the discussions/debates that come up on here. [emoticon]
valhalla360
No paticular place.
Posted: 08/22/22 02:03pm Link  |  Quote  |  Print  |  Notify Moderator
If you are in a 40+ ft rig, it's not going to be an issue because your length would prohibit you from getting into sites that might have width limitations.
Drop down below 30ft and go state/national/older wooded parks and it is occasionally an issue. Not often but it does happen.
Page of 5
