RV.Net Open Roads Forum: Any issues having slides on both sides?
 > Any issues having slides on both sides?
Page of 5
wnjj
Cornelius, Oregon
Posted: 08/22/22 07:10pm Link  |  Quote  |  Print  |  Notify Moderator
4x4van wrote:
As others have said, it's generally not a problem with slides on both sides; very few sites (if any) are that narrow to cause an issue. However, keep in mind that a passenger-side slide intrudes into your camping area.
Couldn't a driver's side slide be worse if you had to move the whole trailer over to miss the utility pedestal?
StirCrazy
Kamloops, BC, Canada
Posted: 08/23/22 09:06am Link  |  Quote  |  Print  |  Notify Moderator
ford truck guy wrote:
It does NOT cut off the back 3rd... That is just not under the awning.. we set up camp and have never not been able to use that " ground" near the rear slides...
Just like anything else, IF you wanna find an issue with something, you probably will.... If you wanna adapt to something, you probably will . .
read the whole post. I said it may or may not affect you depending on how you camp.
if you in parking lots then alls good, but the biggest thing I said that you ignored is your at the mercy of the shape of the site. most of the forest sites I get into with my 40 foot 5th wheel have weird shapes and slides on the pansenger side would reduce the area you have to sit around a fire or not in over 70% of the sites.
If i camped like you in that picture there wouldnt be an issue...
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
StirCrazy
Posted: 08/23/22 09:07am Link  |  Quote  |  Print  |  Notify Moderator
Had to do that once... you learn pretty quick how much room you need haha
Posted: 08/23/22 02:26pm Link  |  Quote  |  Print  |  Notify Moderator
I have parked on ONE site that was not wide enough but it was still not a problem
The rig beside me also extended "over the line" with his slides out so to walk between (IE to access hookups) you walked a "Z" pattern That's in 15 years
Had a few where I had to pull forward/back a bit
The advantage.
You level. then extend slides on ONE side. the rig may "Tilt" that way
Slides out on both sides. Tends to be easier to keep level
dedmiston
Coast to Coast
Administrator
Posted: 08/23/22 02:47pm Link  |  Quote  |  Print  |  Notify Moderator
...Just like anything else, IF you wanna find an issue with something, you probably will.... If you wanna adapt to something, you probably will . .
...And that right there sums up probably 90% of the discussions/debates that come up on here. [emoticon]
No it doesn't.
Yes it does.
No it doesn't.
Yes it does.
Yep.
Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
ol Bombero-JC
Posted: 08/26/22 10:03pm Link  |  Quote  |  Print  |  Notify Moderator
audiocam wrote:
We're looking at buying a new or slightly used TT. Is there any issues with RV's slides on both sides?
My wife thinks they may limit us because some parks may have restrictions on slides on both sides.
Do multiple slide owners have any insights?
Cheers, Scott
Answering the OPs question, SPECIFICALLY in re: "some parks may have restrictions on slides on both sides".
Never found that - or even heard of it. Never stayed in a park w/o sufficient room for slides on both sides of the RV.......also many DPs have 4 slides (or 5) - with slides on both sides........
Sorry, we can't accommodate you - or want your $$. Not !
If the TT is in good shape at a good price, and meets your reqs - don't sweat the small stuff, cheer up and for it.
[emoticon]
WinMinnie02
NJ
Posted: 08/27/22 07:05am Link  |  Quote  |  Print  |  Notify Moderator
Slides add weight to the unit. 2 slides on current unit Class C Winnebago still going strong 20+ years. Make sure you have strong batteries and don't go cheap to operate the slides.
way2roll
Wilmington NC
Posted: 08/27/22 07:34am Link  |  Quote  |  Print  |  Notify Moderator
Newbie hit and run post. Great conversations but value lost to the OP. I know some newbies get scared off with the gruffness of some posters here, but that's not the case on this thread. I always find it odd why some newbies take the time to crate an account and post but never return.
2023 FR Sunseeker 2400B MBS
2112
Posted: 08/27/22 08:58am Link  |  Quote  |  Print  |  Notify Moderator
WinMinnie02 wrote:
.... Make sure you have strong batteries and don't go cheap to operate the slides.
When operating my opposing slides when not connected to shore power I have my truck running and connected to the 7 way plug. My truck provides 14.2V to the battery when the battery is full. Am I fooling myself thinking this helps? I use a single Walmart 27DC in good shape.
2013 KZ Durango 2857
joebedford
Made It!
Posted: 08/27/22 09:35am Link  |  Quote  |  Print  |  Notify Moderator
I once stayed in a park where there wasn't room to put my awning out, but never not enough room for all slides. (on edit: there was one site we were assigned where the next door neighbour had his trailer on the line and his street slide extended over our pad - we couldn't get onto that site even with the slides in. Office gave us a different site)
OTOH, when we overnight in a parking lot somewhere, there isn't enough room to put out our street side slides. Our galley slide (curbside) doesn't go out any further than our front steps - we need steps to get in and out.
5er toy hauler
Often there isn't enough room to put our ramp down - we need to unload motorcycles before we park.
Page of 5
