RV.Net Open Roads Forum: Class A Motorhomes: Gas Class A
 > Gas Class A
Freeway Flyer 05
Pacific Northwest
Posted: 08/11/22 09:57pm Link  |  Quote  |  Print  |  Notify Moderator
We have camped in a Rambler Station Wagon, upgraded to a Dodge van, and Truck Campered or Travel Trailered all over the Pacific Northwest. My lovely bride is not happy with the seats in my 2007.5 6.7 Dodge diesel pickup Tow Vehicle. She actually said, out loud, maybe we should look at a Motor Home. Major shift for us, but I am thinking we should be pretty happy with a gas CLass A. We are tied to our home town until our mom passes, she is 91 and going strong, so no full time diesel pusher. Before we bought our current Toy Hauler TT, I was looking hard at the Winnebago MH. Just looking for opinions, thoughts, and ideas.
Trackrig
Spent the summer in Conconuly, Wa, MH now in Vanco
Posted: 08/11/22 10:08pm Link  |  Quote  |  Print  |  Notify Moderator
The reasons I have a DP - items you don't get on gasser
1. The engine is in the rear so it's a lot quieter up front when driving
2. With the engine in the rear, the generator is up front so it's a lot quieter in the rear bedroom if you need to run it at night
3. With the engine in the rear, you don't have to crawl over the engine to get to the driver's seat
4. The seats are generally more comfortable in a DP
5. Air brakes
6. The retarder to help slow you down
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
craig7h
Branson MO area
Posted: 08/12/22 04:13am Link  |  Quote  |  Print  |  Notify Moderator
A couple years back my DW finally had enough of the "chucking", rough ride that our 1ton dually pulling a 35'5th wheel could give.
We went looking for a MH, a gas one was within budget. We found a nice 29' one that we thought fit the bill. The ride was ok, the seats were not the best but very do able. The engine noise was a little over bearing at times. Nothing that we could not get used to. On the down side that we never even thought about was storage! Being used to the large 5er the gasser had no storage neither inside or out. For weekend use it was great but for long trips not so much.
After the first year we realized we made a size mistake. So off we go looking for larger MH's. Thats when we found an older 37'DP in excellent shape. The ride so much better, its easier for DW to get up and move around when rig is in motion.
Everything that "tracking" had to say was correct. I will add think hard about how you want to use the MH. Do not get two short of a unit, as the change from toy hauler to mh is a big one.
Good Luck you have a big decission to make
Itasca Meridian SE 36g
Road Master Tow Dolly
rgatijnet1
Posted: 08/12/22 05:19am Link  |  Quote  |  Print  |  Notify Moderator
5. Air brakes
Bill
In all fairness to someone who wants a complete list about a DP:
7. Not every repair shop can work on a DP. Most any mechanic knows his way around a gas engine.
8. If repairs are needed they will be much more expensive.
9. You cannot go in to Autozone, etc and get the basic parts like an air filter, oil filter, etc.
10. Diesel fuel is more expensive.
I have had both and I think you need to find a floor plan you like first, and then decide how much you intend to travel. If it involves going from one location to another, and then sit there for months, then you might want to decide if the additional cost for a DP is worth it. You have lots of decisions to make and facts to consider with any RV purchase. Good luck with your search.
phil-t
Ogdensburg, NY
Posted: 08/12/22 05:20am Link  |  Quote  |  Print  |  Notify Moderator
We have been in a gas Class A for 6 years of traveling; living 1/2 of that time in the motorhome. For us, and many, the primary concern is comfort in the living mode. Floor plan that fits your needs and wants is most important.
Yup, the gasser is noisier up front. Handling is generally better in the DP, but not always. Most gassers handling can be improved to satify the driver/occupants.
I think the gas/diesel thing is about "want" no so much need. Depends on how much travleing (miles) you intend to do. There is lots of information out there on this gas vs. diesel discussion.
We started in a 32 ft. Winnebago and are now in a 38 ft.Tiffin Open Road. Very happy with the floor plan and comfort level.
2010 Winnebago Vista 32k on a 2009 Ford F53 22k chassis
Posted: 08/12/22 05:51am Link  |  Quote  |  Print  |  Notify Moderator
Two biggest issues I have with a Class A gasser
1: Cargo Carrying Capacity (All the junk you bring with you) Mine was LESS THAN 1000 pounds
2: Towing: The hitch receiver was rated for 5,000 but after I substracted the GVW (not max but scaled) of the Motor home from the Max CGVW (Combined gross vehcle weight) i was only left with 4,000 for the towed.
Most Big D's have much mroe capacity in both areas.
Noise... Well this old farm boy loves the sound of a big engine working.
blawless
Killaloe, Ontario
Posted: 08/12/22 08:28am Link  |  Quote  |  Print  |  Notify Moderator
As was said earlier find the floor plan you like and then if its a gasser fine if a diesel fine. I have a 36' gasser and it has more storage than many diesels of the same size. Only one thing that wasn't mentioned regarding the diesel MH is the Air brakes. You will require an endorsement on your driver's license for the air brakes. This involves taking and passing air brake course before you can legally drive it. Which may or may not delay being able to drive it. In addition if you become sick etc.. (heaven forbid) while you're out and about does your significant other have the endorsement as well to be able to drive it home or to a safe location while on the road.
This unfortunately never gets mentioned in any of the diesel vs gas MH debates.
Retired and enjoying it!
2005 Coachmen Aurora 3380 MBS Class A F53 V10 Banks Power System.
2014 Jeep Compass Toad
2001 Fleetwood Prowler 255B 5th wheel
2003 F150 King Ranch Supercrew 4X4
way2roll
Wilmington NC
Posted: 08/12/22 08:44am Link  |  Quote  |  Print  |  Notify Moderator
You didn't really say what gas MH you were looking at but it matters. You mention Winnie, but there are all flavors and years. We had a few entry level gas MH's and they did NOT ride very well at all. A lightweight, poorly insulated MH will rattle, roll and be noisy enough to render normal conversations to a screaming match. You are directly over the engine and the V-10 while very capable, is a high revving engine. The suspension isn't great either. Now if you get a higher end, well insulated, heavier rig it might be more manageable. But I don't think I have ever been in a Gas MH (and I've test driven many) that rode better than any passenger truck. If it's comfort and quiet you are after, I think you would look at a DP. Engine in the rear, heavier and an airbag suspension all make for a world of difference. There's storage too. DP's usually have a raised rail chassis which allows for a lot more storage than a gasser. And then there's CCC and towing capacity. Many gassers don't have much left by the time you add water, food, fuel, gear and people. These are usually not a concern with a DP.
Ed C
Cape Cod, MA
Posted: 08/12/22 09:58am Link  |  Quote  |  Print  |  Notify Moderator
We started with a Winnebago Adventurer; moved onto a Itasca Suncruiser (really the same thing) and crossed the country (round trips) eight times with Jean's 80 year old mother. All was well. We are on our second DP and all is better. There is nothing wrong with a quality gas motor home!
Ed/Jeanie & Slade the GSD
2017 Entegra Aspire 42 RBQ/ Sierra Crew
Freeway Flyer 05
Pacific Northwest
Posted: 08/12/22 10:16am Link  |  Quote  |  Print  |  Notify Moderator
Good info all that have contributed so far. Comfort and floorplan are the top things we are looking at, then the chassis and manufacturer. Our trips for the next few years are not going to be any longer than a week or two, and we have time to let the RV price bubble ease off. I have always driven the RV choice, and this time the bride is taking precedence, we are taking our time.
 > Gas Class A
