RV.Net Open Roads Forum: Travel Trailers: propane/water heater
 > propane/water heater
dougbo44
south jersey
Posted: 08/15/22 07:04am Link  |  Quote  |  Print  |  Notify Moderator
Still a rookie.....my question is: when my hot water heater is running, heating my 6gal tank, what will the heater do if the propane tank runs out of propane during the heating process? Will it just shut off? 2015 Forest River Wildwood XLite Suburban heater. thanks in advance!
bgum
South Louisiana
Posted: 08/15/22 08:23am Link  |  Quote  |  Print  |  Notify Moderator
It will simply shut off.
Fisherman
Angus, Ontario, Canada
Posted: 08/15/22 09:15am Link  |  Quote  |  Print  |  Notify Moderator
It would be the same as when your neighbouring camper walks by and turns off your propane tanks. It will turn off, the water won't be heated and the wife will scream blue murder and you're sleeping in the tent.
QCMan
Independent Republic of Horry
Posted: 08/15/22 03:37pm Link  |  Quote  |  Print  |  Notify Moderator
With no fuel it will have nothing to run on. It could not do anything but turn off.
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
MitchF150
Puyallup, WA
Posted: 08/15/22 04:07pm Link  |  Quote  |  Print  |  Notify Moderator
You will also see a "check" light come on the main panel (or at least your should see one) when it does not ignite.
Mitch
aftermath
Washington State
Posted: 08/18/22 03:54pm Link  |  Quote  |  Print  |  Notify Moderator
A related question. Do you have two propane tanks on your trailer? If so you will need to understand how the switch over valve works.
2017 Toyota Tundra, Double Cab, 5.7L V8
2006 Airstream 25 FB SE
Equalizer Hitch
