RV.Net Open Roads Forum: Class C Motorhomes: "Godzilla" Ford V 8
 > "Godzilla" Ford V 8
Johnny Hurryup
Tafton Pa.
Posted: 08/17/22 02:04pm Link  |  Quote  |  Print  |  Notify Moderator
Does anyone know why the new Ford "Godzilla" V8 7.3 liter is rated at 350 HP in a Class C motorhome but 430 HP in a Ford F250 superduty truck? The torque ratings are similar though,
KD4UPL
Swoope, VA
Posted: 08/17/22 07:10pm Link  |  Quote  |  Print  |  Notify Moderator
I would guess it's de-rated because of the heavier duty application. Also, cooling may be an issue with the tighter confines of a van engine compartment versus a truck engine compartment.
bobndot
Posted: 08/17/22 11:28pm Link  |  Quote  |  Print  |  Notify Moderator
I guess the idea was for the rv engine to get better mpg's.....???
bc it's operating at lower rpms where its tuned to get peak HP and torque at a lower rpm ,
where the fuel injection settings are tuned at peak.
Super Duty chassis with the 7.3 engine is tuned to produce 430 hp at 5,500 rpm. The Premium RV 7.3 is tuned to produce 350 hp at 3,750 rpm.
I think its better suited for the rv which is always hauling its weight where a P/u is not. To have power early on , lower rpm's, is a benefit in an rv.
JaxDad
Greater Toronto Area
Posted: 08/18/22 05:43am Link  |  Quote  |  Print  |  Notify Moderator
Engines are normally de-rated for ‘severe service’ applications like an RV where there is no such thing as “empty miles” like the majority of driving is with a pickup truck or even a cube van. It makes a big difference in durability and longevity.
In Ford’s case, it was something they’ve been doing from their earliest days with their farm tractors.
As an example, a ‘typical’ Ford tractor, a 3000 utility tractor has a 2.6 liter (158 cu. in.) gas engine, de rated to 46.7 hp. By comparison, a pretty well-reputed typical automotive engine, the Mitsubishi 2.6, is rated at 135 hp.
We have a Ford 3000 gas tractor, the engine has had (or needed) anything but maintenance since it was produced in 1965, it currently has a little over 10,000 hours on it. If you use the conversion speed of an average of 45 mph, that would suggest it has the equivalent of 450,000 miles on it. It still has no real wear evident, no oil consumption or blow by, etc.
Posted: 08/18/22 10:52am Link  |  Quote  |  Print  |  Notify Moderator
^ What he said. Although it doesn't really make sense since all the F series up through the F450 get the full power version and the gcvwr of the E series is much lower than many available F series class 3 and 4 trucks.
Similarly, the E series, cutaways, Class A chassis and bread trucks also only come with a 6 speed.
Moreso, I would bet it comes down much less to the durability and duty cycle rating and is primarily a cost saving measure. Which is somewhat easily justified in that the "performance" (power and speed) of a utility vehicle is much less of a selling point to plumbers and RVers than it is to F series buyers, who actually tow much heavier with class 3-4 trucks.
And with no real competition to beat (other than Chevy who isn't even close in market share and also not winning the power/transmission battle anyway), no reason for extra cost to give someone a faster class C or work van.
In other words, Ford is not chasing a carrot with these models. They are the carrot, albeit a lower HP de-rated carrot.
2017 Heartland Torque T29
Tom_Anderson
NorCal
Posted: 08/18/22 01:19pm Link  |  Quote  |  Print  |  Notify Moderator
I'd be interested to know how many HP the pickup truck version produces at 3750 RPM. My guess is that it's not much (if any) more than the motorhome version.
rjstractor
Maple Valley, WA
Posted: 08/18/22 08:16pm Link  |  Quote  |  Print  |  Notify Moderator
From what I understand it has to do with how horsepower is rated in the commercial chassis over 14K GVWR. I looked on Ford's website, and all of the cab and chassis F series, even the F350, had 7.3 ratings of 335-350 hp. Interestingly, there were 2WD F350s listed with GVWRs of upwards of 16K. Maybe someone more knowledgeable will chime in, but I seem to remember the real-world output of the engines in the commercial chassis is the same as the consumer-marketed pickups, the only difference is due to how the engines are rated.
pnichols
The Other California
Posted: 08/19/22 11:02am Link  |  Quote  |  Print  |  Notify Moderator
Hmmm ... other than in drag, or closed course, racing ... what pickup driver (or RV driver) revs their 7.3 V8 to 5,500 rpm?
I'm guessing that the "RV tuned version" of the 7.3 V8 would probably be putting out close to 430 hp too ... at 5,500 rpm.
Tom_Anderson
NorCal
Posted: 08/19/22 11:23am Link  |  Quote  |  Print  |  Notify Moderator
This is the point I was trying to make. It's just rated at a different RPM. That doesn't mean it's detuned.
valhalla360
No paticular place.
Posted: 08/19/22 11:48am Link  |  Quote  |  Print  |  Notify Moderator
With private sales, bragging rights sell, so Ford wants to show the biggest numbers reasonably possible. Realistically, how many people drop $70-90k on a truck and go around with it floored at 5,500rpm with a heavy load.
For fleet sales, detuning it a bit for more long term durability is a selling point. If they really need 400+hp, they are likely moving up to something heavier duty with a diesel. Also, keep in mind, the driver has no skin in the game, so it's desirable to have the engine protect itself from an idiot driver.
MH's happen to use a commercial chassis, so they aren't going to uprate them just for that use.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
