Bionic Man
New 3.0 diesel announced. I'm happy to see these continue their run. If I were in the market for a GM 1500, there is no question that this would be on my short list.
Duramax
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
Southern California :(
No “first year in production” worries?
FishOnOne
The Great State of Texas
Steel pistons!!!!
I like and dislike having the DPF next to the engine. I like that the natural exhaust temps will probably create better passive regens on the DPF which should reduce the frequency of active regens. I don't like having the DPF creating all that heat during an active regen next the engine and surrounding components.
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs
"250k Miles"
'16 Sprinter 319MKS "Wide Body"
^Ya, a lot of heat under the hood. Or maybe it’s really well insulated?
But basically LB7 power in a small displacement 1/2 ton is impressive to say the least.
ksss
Eastern Idaho
GM has done a good job with this half ton diesel. No real issues on the original 3 .0 and I doubt this one will be any different. The MPG has been impressive. Hopefully all of that continues. There is a fine line between performance and economy and GM seems to have found that line. Also impressive is the price is reasonable for the 3.0 and hopefully that doesn't change either.
2020 Chevy 3500 CC 4X4 DRW D/A
2013 Fuzion 342
2011 RZR Desert Tan
2012 Sea Doo GTX 155
2018 Chevy 3500HD CC LB SRW 4X4 D/A
2015 Chevy Camaro ZL1
mkirsch
Rochester, NY
First question: Does it have a lifter seizing problem?
Second question: Why do they do that weird thing with the RPO code? LM2 --> L20? Why not LM2 --> LM3?
FishOnOne
mkirsch wrote: First question: Does it have a lifter seizing problem?
I'm sure this engine does not have the lifter issue. That problem is with the gas V8 engines with displacement on demand
edited 08/22/22 07:27pm by FishOnOne *
blofgren
Surrey, B.C.
Thanks for posting; this looks great! Does anyone know if they plan on installing this in the Yukon/Tahoe platforms? That may be our future SUV if that is the case.
The DPF location is certainly interesting. It would eliminate the theft problem of them though.
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, B&W RVK3670 hitch, Retrax, Linex, and a bunch of options incl. cargo camera
FishOnOne
blofgren wrote: Thanks for posting; this looks great! Does anyone know if they plan on installing this in the Yukon/Tahoe platforms? That may be our future SUV if that is the case.
GM already offers the 3.0 Duramax in the Tahoe/Yukon. Better get one now before they obsolete them.
blofgren
Surrey, B.C.
FishOnOne wrote: blofgren wrote: Thanks for posting; this looks great! Does anyone know if they plan on installing this in the Yukon/Tahoe platforms? That may be our future SUV if that is the case.
Yes, I've seen several of them, but are they installing this new version in them?
