RV.Net Open Roads Forum: Travel Trailers: Schwintech slide system
 > Schwintech slide system
johned
carbondale, colorado
Posted: 08/20/22 08:35am Link  |  Quote  |  Print  |  Notify Moderator
Hey, right off the bat my new Northwood Nash 23D had the Schwintech slide jamb up on me. Got the factory to replace it and it seems to be doing fine now. However, in my research on the net I've found lots of horror stories about the system. I know most postings are about problems and not successes, however, I would like to hear from anybody who has NEVER had a problem with their Schwintech slide and what they've been doing to keep it that way.
afidel
Cleveland
Posted: 08/20/22 11:47am Link  |  Quote  |  Print  |  Notify Moderator
Most of the horror stories are from folks who has the system horribly misapplied by the engineers at the manufacturer. Schwintech had very specific design guidence about where their system should be used, some manufacturers used it in slides that were twice as long and 4x as heavy as specified. Your single dinette slide should most likely be fine. Lube it as called for in the manual, don't stop with the slide partway in or out, keep the bulb seals treated and it should give you many years of service.
2019 Dutchman Kodiak 293RLSL
2015 GMC 1500 Sierra 4x4 5.3 3.42 full bed
Equalizer 10k WDH
PButler96
Midwest
Posted: 08/20/22 12:35pm Link  |  Quote  |  Print  |  Notify Moderator
Oh Nooooo, a broken Northwood product, we'll I never.
I have a burn barrel in my yard.
Old Days
Colorado
Posted: 08/20/22 12:39pm Link  |  Quote  |  Print  |  Notify Moderator
What we do, put shims under the slide when we travel that way it does not bounce around when you travel, and don't overload the drawers and keep it lubed. Never have had a problem.
MitchF150
Puyallup, WA
Posted: 08/20/22 01:26pm Link  |  Quote  |  Print  |  Notify Moderator
Here is a youtube vid on the 3 main slide systems.. The video is 'indexed', so you can ff to any part that interests you, but he goes over the Schwintech slide system along with cable and rack and pinion slides..
https://www.youtube.com/watch?v=DkgYjoijTNI&t=3s
B-n-B
Colorado
Posted: 08/20/22 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
Same camper as you. No problems here. As mentioned, don't stop part way in/out. I've read elsewhere to hold the power 2-3 seconds beyond what you perceive as the end of slide travel going in or out.
The part you lube is not the part you see on the side of the slide, just keep it debris free. The part to lube is hidden behind the seals.
https://www.youtube.com/watch?v=gXw9I_DoAvI
2006 Ram 3500 SRW 4x4
5.9L Cummins
2019 Nash 23D
southernsky
Ponchatoula La.
Posted: 08/21/22 05:09am Link  |  Quote  |  Print  |  Notify Moderator
Six years and many many miles, open and closed hundreds of times. Never had a lick of problems. Lubed as required and run all the way in, all the way out holding button about 5 seconds after it stops.
2022 Renegade Super C
2020 Ford Ranger 4x4 Sport
klutchdust
Orange, California
Posted: 08/21/22 10:41am Link  |  Quote  |  Print  |  Notify Moderator
why don't you go play with a table saw and remove the guard first. lol
johned
Posted: 08/23/22 04:39pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks to those of you who addressed my concern. You were helpful.
ScottG
Bothell Wa.
Posted: 08/23/22 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
That slide system has been revised several times and the latest iteration works well. Mine is 4 y/o and has never had an issue.
I would not hesitate to buy another.
