RV.Net Open Roads Forum: Beginning RVing: tire pressure
 > tire pressure
timpitt
san diego ca
Posted: 08/20/22 01:15pm Link  |  Quote  |  Print  |  Notify Moderator
We have 2021 fleetwood bounder 33c what is a good psi for the tires
when loaded We will be towing a Ford ranger.
KD4UPL
Swoope, VA
Posted: 08/20/22 01:26pm Link  |  Quote  |  Print  |  Notify Moderator
It should be listed on the door sticker. With no other information inflate to the maximum on the sidewall. To really set it right you need to weight the RV fully loaded and get axle weights. Then, look up your tires on the manufacturer's load inflation table and inflate to the pressure for that weight.
USAFBILL
Alabama
Posted: 08/20/22 01:58pm Link  |  Quote  |  Print  |  Notify Moderator
Towing with a Ford Ranger might be an issue.....sorry misread
* This post was edited 08/21/22 12:16pm by USAFBILL *
2003 Cougar 285EFS
2000 Chev 2500 Ex Cab
Southern California :(
Posted: 08/20/22 02:13pm Link  |  Quote  |  Print  |  Notify Moderator
Isn’t the Bounder a motorhome, Bill?
Mike134
Elgin, IL
Posted: 08/20/22 02:17pm Link  |  Quote  |  Print  |  Notify Moderator
he could tow your 2500 with no issue
2019 F150 4X4 1903 payload
2018 Adventurer 21RBS 7700 GVWR.
wildtoad
Blythewood, SC
Posted: 08/20/22 07:01pm Link  |  Quote  |  Print  |  Notify Moderator
Until you get it weighed, go with the pressures listed on a placard in your RV, or use the axle weights on the placard and use the tire manufacturers charts.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
QCMan
Independent Republic of Horry
Posted: 08/20/22 07:54pm Link  |  Quote  |  Print  |  Notify Moderator
Towing a Ranger, not towing with. A Bounder is a motorhome.
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
Good Sam Life Member
Desert Captain
Payson
Posted: 08/20/22 09:05pm Link  |  Quote  |  Print  |  Notify Moderator
"To really set it right you need to weight the RV fully loaded and get axle weights. Then, look up your tires on the manufacturer's load inflation table and inflate to the pressure for that weight. "
Yep, using the sticker and blindly inflating to the max on the sidewall is a very bad idea. Also, how old are the tires? Check the DOT codes and if they are 5 years old or more plan on replacing them soon.
Good luck.
[emoticon]
joelc
Cedar Point, NC
Posted: 08/21/22 06:48am Link  |  Quote  |  Print  |  Notify Moderator
I use the pressure noted on the tire, not the pressure printed on the vechile.
CapriRacer
Somewhere in the US
Posted: 08/21/22 07:42am Link  |  Quote  |  Print  |  Notify Moderator
Once again, I am reminding people that those load/inflation pressure charts are MINIMUMS, NOT recommendations.
CapriRacer
Visit my web site: www.BarrysTireTech.com
 > tire pressure
