RV.Net Open Roads Forum: Tech Issues: New 12 volt compressor refrigerators
 > New 12 volt compressor refrigerators
Johnny Hurryup
Tafton Pa.
Posted: 08/21/22 07:43am Link  |  Quote  |  Print  |  Notify Moderator
I'm seeing these new 12 volt compressor refrigerators in RVs. Anyone have experience with them? Plusses minusses???
Southern California :(
Posted: 08/21/22 08:20am Link  |  Quote  |  Print  |  Notify Moderator
If dry camping you will need adequate batteries and a method of recharging. Solar is the easiest and works most days. Estimate average daily amp use, multiply my at least 1.5 and build from there. What is amp use of the 12 volt fridge you are considering?
Posted: 08/21/22 08:28am Link  |  Quote  |  Print  |  Notify Moderator
I do not use one of them but I have a 'Chest style" Freezer/fridge(one or the other) The original was an Engel lasted 16 years Loved it. the new one is an LG.. It too is good but ... I don't trust LG products as a rule.
These units suck less than 50 watts with the door closed V/s 350 for an absorption cooling unit.
Though I'm out of the RV life just now (not entirely by choice but.. it's a good thign) If I get back in I'll be SERIOUSLY looking at 'em.
Second Chance
Wherever...
Posted: 08/21/22 08:50am Link  |  Quote  |  Print  |  Notify Moderator
Grand Design is putting them in a lot of their travel trailers, and has been for a while now. From the postings on one of the forums they seem to be a lot better at holding set temps than an absorption refrigerator. Of course, one has to have the battery and solar capacity to support the fridge off-grid since you can't run it on propane. There have been a few failures, but mostly with the Furrion brand, IIRC. (Disclaimer: we have a 120VAC residential fridge, so this is only from seeing everything posted on one of the Grand Design forums.)
Rob
* This post was edited 08/21/22 10:26am by Second Chance *
U.S. Army retired
2020 Solitude 310GK-R
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
johnhicks
Wandering below the Gnat Line
Posted: 08/21/22 10:23am Link  |  Quote  |  Print  |  Notify Moderator
https://www.rvtravel.com/12-volt-refrigerator-rvt-1065/
-jbh-
pianotuna
Regina, SK, Canada
when my dometic dies I'll replace with a compressor fridge.
Regards, Don
Second Chance
Wherever...
Posted: 08/21/22 10:25am Link  |  Quote  |  Print  |  Notify Moderator
Clicky
bikendan
Goodyear, Arizona
Posted: 08/21/22 11:25am Link  |  Quote  |  Print  |  Notify Moderator
During the pandemic, RV manufacturers found 12v only fridges were cheaper and easier to install, hence the change from 2-way RV fridges.
There were many issues from the start, especially with ones from Furrion.
Bottom line is that you'll needa a minimum of 200w of solar and most move to a lithium battery bank setup.
Dan- Firefighter, Retired">, Shawn- Musician/Entrepreneur">, Zoe- Faithful Golden Retriever(RIP">), 2014 Ford F150 3.5 EcoboostMax Tow pkg, 2016 PrimeTime TracerAIR 255 w/4pt Equalizer and 5 Mtn. bikes and 2 Road bikes
Posted: 08/21/22 11:56am Link  |  Quote  |  Print  |  Notify Moderator
Yes, Don, but you are juiced far beyond most of us!
Skibane
San Antonio, TX
Posted: 08/21/22 01:12pm Link  |  Quote  |  Print  |  Notify Moderator
bikendan wrote:
Bottom line is that you'll need a a minimum of 200w of solar
If you can't find a camping spot with plenty of sunlight exposure, having all the solar panels in the world won't help.
From a practical perspective, there are times when you're going to need a backup plan for recharging the batteries.
