RV.Net Open Roads Forum: Fifth-Wheels: Landing gear all the way down.
 > Landing gear all the way down.
grizz272
frozen tundra, WI
Posted: 08/22/22 02:22am Link  |  Quote  |  Print  |  Notify Moderator
My nose cone needs a good washing. I was thinking about lowering the landing gear all the way down to provide a lower height to wash the nose cone.
What is the chance that when the gear is down I will not being able to raise the gear all the up again?
bucky
Raleigh metro
Posted: 08/22/22 04:25am Link  |  Quote  |  Print  |  Notify Moderator
I do it all the time. No different than a badly sloped campsite.
2005 Cummins 3500 2WD LB quad cab dually pulling a 2014 Blue Ridge 3025RL
schlep1967
Harrisburg, PA
Posted: 08/22/22 05:09am Link  |  Quote  |  Print  |  Notify Moderator
As long as you have a fully charged battery you should be fine. Better if you can be plugged in at the time so the converter can help the battery.
2021 Chevy Silverado LTZ 3500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide 4500
MFL
Midwest
Posted: 08/22/22 05:23am Link  |  Quote  |  Print  |  Notify Moderator
I agree, but I normally try to avoid hitting the absolute stop, even when raising the legs for travel. I have a mark on the leg, about a 1/2" from hard stop. IMO, doing this is just easier on the components, especially with full wt on the legs, like the OP is asking.
Jerry
ford truck guy
Pennsylvania
Posted: 08/22/22 08:03am Link  |  Quote  |  Print  |  Notify Moderator
I back my truck to the nose and climb into the bed to wash the nose.....
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
Flashman
Tucson, Aizona, USA
Posted: 08/22/22 07:13pm Link  |  Quote  |  Print  |  Notify Moderator
That's what I do.
grizz272
frozen tundra, WI
Posted: 08/28/22 02:51pm Link  |  Quote  |  Print  |  Notify Moderator
My drive way slopes a little where I park the camper. Even in the bed of the truck it is hard to get a good scrub on the nose.
StirCrazy
Kamloops, BC, Canada
Posted: 08/29/22 08:41am Link  |  Quote  |  Print  |  Notify Moderator
you hit the hard retract stop every time you get ready to leave. its the full extension that causes the issues.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
bobbyg123
Duvall, WA
Posted: 08/30/22 08:00pm Link  |  Quote  |  Print  |  Notify Moderator
Steve
I never use the "retract all" button when I'm ready to pull out because I thought it wasn't advisable to pull the jacks all the way up. I always stand there like a dumbass holding the button, which probably causes more problems.
2018 Jayco Eagle HT 29.5BHDS
2017 Ford F-350 CC 6.2L
schlep1967
Harrisburg, PA
Posted: 08/31/22 06:24am Link  |  Quote  |  Print  |  Notify Moderator
We camped at a State park last weekend. We booked the site on the internet last spring without going and looking at it. It sloped downward from the road. When I got backed in the cheap level I have stuck to the side of the trailer was pegged all the way forward. Past the 7" mark on the level vial. I ran the legs down as far as I thought I could. Then dropped the feet a few inches to the ground. Got the weight on the feet and unhooked. I then had to run the legs up what I'm estimating as around 22 inches, probably more, to get the nose down to a level position. When it came time to leave it ran right back up to where I needed it to to hook up again.
Fit the site perfectly. Rear of the trailer was 3 inches from a tree. All 4 slides had no obstructions close. The front of the awning missed a 4 foot wide oak tree by 3 inches.
