RV.Net Open Roads Forum: Need help with name of item for main tv
 > Need help with name of item for main tv
RJL
Manahawkin, New Jersey
Posted: 08/23/22 07:35am Link  |  Quote  |  Print  |  Notify Moderator
Hard for me to explain.
What's the name of the piece of equipment where you select cable, air, vcr, dvd and satellite for the tv?
I think mine may be on the fritz.
Thank you.
Bob
2010 Damon Challenger 368, F-53 Chasis
2010 Jeep Wrangler Rubicon unlimited, Toad
2018 Ram 1500 4x4, Club Cab, 6.4 bed,3.92 gears, 5.7 HEMI
2019 Dodge Challenger Scat Pack Wide Body, 6.4 HEMI
way2roll
Wilmington NC
Posted: 08/23/22 07:38am Link  |  Quote  |  Print  |  Notify Moderator
RV video switch box.
RJL
Posted: 08/23/22 07:44am Link  |  Quote  |  Print  |  Notify Moderator
Thank you!
JoeH
Apollo Beach,FL
Posted: 08/23/22 07:45am Link  |  Quote  |  Print  |  Notify Moderator
aka BOMB ( box of many buttons)
Joe
2013 Dutch Star 4338- all electric
Toad is 2015 F-150 with bikes,kayaks and Harley aboard
Dutch_12078
Winters south, summers north
Posted: 08/23/22 07:46am Link  |  Quote  |  Print  |  Notify Moderator
Also known as a "BOMB" (Box Of Many Buttons). [emoticon]
Dutch
2001 GBM Landau 34' Class A
theoldwizard1
SE MI
Posted: 08/23/22 08:35am Link  |  Quote  |  Print  |  Notify Moderator
MAYBE !
if you have OLD equipment that has screw type F-connectors, then this is likely what you want. Even a compatible connector is not a guarantee as depending on the vintage of the equipment you have it may or may not "play well together"
More modern televisions (anything built after 2009) do have a screw type connector, but will NOT accept a signal from old VCRs or old DVD players. Older televisions will NOT accept a signal from "over the air" (OTA) TV broadcasts or modern DVD/Blu-Ray players.
The current universal input for televisions (except for OTA and cable) is called HDMI. It looks and works completely different.
OTA and cable still come in on coax cable with a screw connector, but they use a different/incompatible signal.
Getting old equipment to work with new equipment is frustrating, expensive and will give poor results. I bought a spare DVD/Blu-Ray player last year for under $100.
Southern California :(
Posted: 08/23/22 12:10pm Link  |  Quote  |  Print  |  Notify Moderator
My newer TVs let me plug in everything and I select which source the TV displays on the TV screen. No "box" or equipment.
Posted: 08/23/22 02:23pm Link  |  Quote  |  Print  |  Notify Moderator
As someone said RV Video Switch box
Technical name "Matrix switch"
I call it "Box of Many Buttons"
They come in different configurations but here is a link to an example
(2,3,4,5.6 on 2,3,4 out are examples of different configs)
Some switch ONLY Video, some Video and RF Some HDMI some Composit.
Here is an example
theoldwizard1
SE MI
Posted: 08/24/22 02:21am Link  |  Quote  |  Print  |  Notify Moderator
When HDTV first came out, 4 HDMI inputs were common. Now you are lucky to get 2 !
bucky
Raleigh metro
Posted: 08/24/22 03:20am Link  |  Quote  |  Print  |  Notify Moderator
The remote does ours. In the RV and at home.
2005 Cummins 3500 2WD LB quad cab dually pulling a 2014 Blue Ridge 3025RL
