trblse
Westerville, Ohio
Any recommendations for the best portable Hot Spots for RVs? Lots of remote camping.
ktmrfs
Portland, Oregon
are you just looking for a hot spot and have cell reception? If so easiest and least expensive is to use your phone as a hot spot. next is to get a hot spot from your cell carrier, but that (a) costs and (b) is considered an additional device hence an additional monthly charge.
If your looking for something to boost your signal when you are in marginal areas, a hot spot is NOT the solution, a cell phone booster is a solution.
2011 Keystone Outback 295RE
theoldwizard1
SE MI
There are many to choose from but obviously you want one that works with your plan ! Don't spend extra for 5G. It will be sometime before 5G is going to be available outside of cities. Last, shop for one that has inputs for 2 antennas. If you get inspired you can mount a pair on a pole and raise it up. It will improve your reception a lot.
FMCA's Tech Connect. 50 setup 50/month NO LIMIT on Data
Second Chance
Wherever...
Lots of good information here:
RVmobileinternet.com
Rob
U.S. Army retired
2020 Solitude 310GK-R
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
Tzman4
Mesa, AZ
Hi-tech Living.com
Dennis & Patty Martin, Sami & Sassy
2011 F450 KR
2021 Forest River RiverStone Legacy 42FSKG
2020 HD FXST
pianotuna
Regina, SK, Canada
Hi,
I have unlimited data on both my phones (each is with a different carrier). One throttles at 50 gigs; the other at 30 gigs. I can still watch netflix even when throttled.
Regards, Don
Rbertalotto
Massachusetts
I have two Netgear Unite Explore hotspots. One on unlimited AT&T Mobley and one on T-Mobile 20g . these are vintage hotspots but have all the features I need and are still working 100% where ever I travel. They have great battery life, dual antenna input and excellent WiFi distance reception. Until Star link gets 100% up and running, ill keep using these devices.
RoyB
Dartmouth, MA
2021 RAM 2500 4X4 6.4L
2011 Forest River Grey Wolf Cherokee 19RR
520 w solar-200ah Renogy Li-Epever MPPT
LouLawrence
Traveling the US!
Gotta love my Mobley and a Netgear hotspot. With unlimited data and $23/month it's a winner. No longer available, of course, but great if you grabbed on awhile back!
ralphnjoann
Colorado
Calyx Institute offers a $400 a year plan, plus a one-time $100 payment for the hotspot. It is unlimited 4G using T-Mobile. They also have a 5G unlimited plan costing $500 per year plus a $200 one-time charge for the hotspot. The payments are made up front and then annually thereafter.
I've been using them for 6 months and have had no problems.
