RV.Net Open Roads Forum: Tow Vehicles: Tongue weight limits and wdh
Search only in Tow Vehicles
 > Tongue weight limits and wdh
Page of 5
ktmrfs
Portland, Oregon
Posted: 08/26/22 11:53am Link  |  Quote  |  Print  |  Notify Moderator
valhalla360 wrote:
ktmrfs wrote:
Agreed that the trailer axle weights go up, as does the TV front axle and the truck rear axle weight goes down. But the sum of the three axle weights stays the same That means the tongue weight hasn't changed. Now since many scale weights have a 25 or 50lb increment that may cause a slight difference but it is due to scale resolution.
If the tongue weight changes then that force needs to be accounted for in the force on the TV and trailer axles. If the tongue weight goes down, then the sum of the weight on the other axles must go up to account for it.
Now, if the tongue was nose down w/o wd and now level, there could be a slight decrease in tongue weight due to the trailer attitude which would show up in the weight calculations. But it is going to be minor.
Umm..no
The WDH moves some of the tongue weight back onto the trailer axles.
Nose up or down, doesn't impact the weights enough to notice.
How much did the sum of your TV front axle, rear axle and trailer axle change? that is how much the tongue weight changed. I bet the sum of the weights didn't change by more than 50lbs.
The WD hitch moved weight from the TV rear axle to the trailer and TV front axles.
2011 Keystone Outback 295RE
bikendan
Goodyear, Arizona
Posted: 08/26/22 06:38pm Link  |  Quote  |  Print  |  Notify Moderator
waynefi wrote:
What happens with the tongue weight limit when you are using a weight distributing hitch?
My Tacoma says the the tongue weight limit is 650 lbs. Does that mean that if my trailer has a tongue weight over 650 I need a wdh, or that I shouldn’t pull that trailer even with a wdh?
The function of a wdh is to take weight off the tongue, right? How would you even measure the tongue weight with the wdh in place?
My current trailer has a nominal tongue weight of 380, but that is before water, a second battery, etc.
Your Taco's owners manual towing section should detail how much tongue or trailer weight, will require a WDH.
Dan- Firefighter, Retired">, Shawn- Musician/Entrepreneur">, Zoe- Faithful Golden Retriever(RIP">), 2014 Ford F150 3.5 EcoboostMax Tow pkg, 2016 PrimeTime TracerAIR 255 w/4pt Equalizer and 5 Mtn. bikes and 2 Road bikes
waynefi
S E Michigan
Posted: 08/26/22 08:18pm Link  |  Quote  |  Print  |  Notify Moderator
The Taco owner’s manual says I need a wdh for a trailer above 5000 lb, but it doesn’t say what tongue weight it expects for that trailer. My trailer is 3700 empty, but I still use a wdh.
rPod 195
formerly Rockwood MiniLite 1809S
Tacoma V6
Posted: 08/27/22 12:05pm Link  |  Quote  |  Print  |  Notify Moderator
Then you’re already wearing the proverbial second pair of underwear as an “insurance policy”. Time to be “ok” with it.
Or think of it another way. If Yoda isn’t worried about their liability enough to have more info or limitations than what you read in your official Toyota owners manual, then you can take solace in the fact that it IS NOT and issue.
valhalla360
No paticular place.
Posted: 08/27/22 01:46pm Link  |  Quote  |  Print  |  Notify Moderator
The total of all axles (truck and trailer) doesn't tell us anything about tongue weight.
The tongue weight is the weight of the trailer minus the weight on the trailer axles.
Alternatively, you can also do it by comparing the truck axle weights by themselves vs the truck axle weights with the trailer attached. The difference is tongue weight.
With the WDH attached, more weight is on the trailer. On mine, the CAT scales said it was around 200lb less with the WDH connected vs just the ball by itself (bars were placed on the A-frame so the weight of the bars didn't impact the results).
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
ktmrfs
Portland, Oregon
Posted: 08/27/22 10:40pm Link  |  Quote  |  Print  |  Notify Moderator
more weight is on the trailer axles, but less weight is on the TV axles. WD hitch does NOT change tongue weight. All it does is change the axle weight loading of the trailer and TV.
Myth 1: Using a Weight-Distribution Hitch Decreases My Tongue Weight!
This myth is like a cockroach: It’s nasty, dangerous, and hard to kill.
The purpose of a weight-distribution hitch is to restore weight to the front axle that was transferred to the rear axle of your tow vehicle.
In doing so, it transfers some of the hitch weight to the axles of your trailer.
This can be a difficult concept to grasp (believe me, I know!) – but a weight-distribution hitch doesn’t reduce the tongue weight of your camper! It applies a moment (torque) at the connection to reduce the hitch weight seen by your truck.
Posted: 08/28/22 10:34am Link  |  Quote  |  Print  |  Notify Moderator
^Good explanation, for a topic that has now also gone into the depths of speculation and lack of conceptual understanding.
To add, though, while wdhs are now seeking to be the catch all security blanket for RVers now for however many years. The original concept was and still IS to reduce the effective tongue load or weight on a vehicle that is not sufficiently equipped or rated to handle that static tongue weight.
Agree 100% with what you said, but there will be responses refuting it because, well, rvnet….
mosseater
Dillsburg, PA
Posted: 08/30/22 05:46pm Link  |  Quote  |  Print  |  Notify Moderator
On my sig pic truck (traded) my hitch receiver rating for tongue weight was 800 on the bare ball, and 930 for the WD rating. That was exactly 10% of max towing weight of 9300 lbs. my tongue weight was around 1000 so I began the search for info regarding hitch upgrades. Turned out, the OEM Ford receiver was the same receiver used on all the trucks. Only the sticker changed to reflect the as-build ratings of that particular truck. I think the max tongue weight rating for that year was 1500 lbs. WD. But it was the same unit as mine and all the rest which were rated for less. Logic says it was based on the capbility of the truck more than the receiver itself.
Sunset Creek 298 BH
valhalla360
No paticular place.
Posted: 08/31/22 09:38am Link  |  Quote  |  Print  |  Notify Moderator
I agree, the point is to move weight back onto the steering axle and it does create a moment arm at the hitch.
But if it's taking weight off the truck and putting it on the trailer axles, by definition, it's reducing the hitch weight.
So far you have shown no "myth".
Huntindog
Phoenix AZ
Posted: 08/31/22 10:16am Link  |  Quote  |  Print  |  Notify Moderator
Try to imagine a tiny scale that would fit between the top of the ball and the coupler. What it would measure is the actual TW.... And that scale would read the same no matter what is done with WD.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1860watts solar,800 AH Battleborn batterys
2020 Silverado HighCountryC CD/A 4X4 DRW
Page of 5
