RV.Net Open Roads Forum: Tow Vehicles: What is this cat scale telling me?
Search only in Tow Vehicles
 > What is this cat scale telling me?
blt2ski
Kirkland, Wa
Posted: 08/26/22 10:10am Link  |  Quote  |  Print  |  Notify Moderator
Your trailer hitch added 320 lbs to RA, plus it took 100 lbs OFF the FA, for an increase of 420 lbs to RA.
Hitch tongue etc is 320 lbs.
As noted, you and maybe some others are no taking into account the 100 off the FA.
If had a dual axle, and trailer was not level, ie nose down, it's possible the HW would be less than 320, as some wt from trailer axles was taken off, added to RA.
Reality, your ser set up fine.
I do have to admit, I usually prefer 15-17%HW with single axle trailers, 12-14% with dual axle trailers, assuming a bumper/ball/pintle hitch setup.
Marty
2014 Chevy 1500 Dual cab 4x4
JRscooby
Indepmo
Posted: 08/26/22 01:04pm Link  |  Quote  |  Print  |  Notify Moderator
tealboy wrote:
Seriously, the tongue is 420? I hope that’s not right I was coming up with 320. The suv is rated for 350 tongue and 3500 trailer. The tongue feels very heavy to me but I never dreamed it was 420.
As far as handling, I just drove it in a 5 hour trip and it did great. Everything felt good and the squat seemed to only be 2”. The vehicle is a Lexus rx350 with tow pkg.
NO! THERE IS NO WAY TO FIGURE AND GET A TW OF 420! Your TW is 320. It would get little heavier if you lowered the tongue in relation to axle, but unless you re-arrange things you are unlikely to get over the 350.
tealboy
orlando, fl
Posted: 08/26/22 08:26pm Link  |  Quote  |  Print  |  Notify Moderator
Great, thank you Marty and scooby, I didn’t see your latest posts earlier. Some of the others spooked me, thinking I had 420. I didn’t think so but I’m still learning. Your input is appreciated.
* This post was edited 08/27/22 04:59am by tealboy *
dodge guy
Bartlett IL
Posted: 08/27/22 05:49am Link  |  Quote  |  Print  |  Notify Moderator
To know for sure weigh the tongue with the bathroom scale method.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
JRscooby
Indepmo
Posted: 08/27/22 07:00am Link  |  Quote  |  Print  |  Notify Moderator
You would be hard pressed to convince me a bathroom scale/beam set up will read within the 20 lbs the cat rounds things. He is far enough from the hitch limit we know not over, so not too heavy. He has not mentioned any handling issues, so not too light.
Posted: 08/27/22 12:00pm Link  |  Quote  |  Print  |  Notify Moderator
I’m sure some of you, maybe?, realize that computing tongue weight by simply calling the rear axle weight addition the tongue weight is only a good approximation.
If you neglect things like rotational friction and stiffness of members (lol) you can do a moment diagram based on the lengths to each point (axles and hitch) and weights observed at each axle and get pretty close.
But it’s NOT 320+100= 420. Nor is it exactly 320.
But if one is really thst concerned then google and 8th grade math will get you a very close number without actually weighing the tongue. (Which technically would have to be AT the ball and not at the jack if you’re handwringing for that answer that is not just 98% correct but 100%.
And then let’s not get into dynamic forces and how much of that was designed into the static weight rating and if one could exceed that in the right conditions or never reach that in different conditions.
FFS, it’s a little trailer behind a truck that is capable and rated for it. And the OP has done his due diligence to see that he’s in the ballpark.
Next caller please…
tealboy
orlando, fl
Posted: 08/27/22 12:37pm Link  |  Quote  |  Print  |  Notify Moderator
For fun, I brought home a 400lb big game scale from the hunt ranch. I’m going to weigh it since I can but not bc I have any doubt about the actual weight of the tongue.
Edit: just weighted using game scale and came up with 285. Used bathroom scale which maxes at 300 and I got 295. Cat scale indicated 320.
More variances than I would prefer since I like to be precise but bottom line is, no matter what scale I use, I’m under tongue rating.
* This post was edited 08/27/22 02:15pm by tealboy *
JRscooby
Indepmo
Posted: 08/27/22 04:10pm Link  |  Quote  |  Print  |  Notify Moderator
Cat rounds to 20 lbs. And if you set the coupler on the scale higher than when hooked to TV, the scale will read light
Me Again
Sunbird(Wa)/snowbird(Az)
Posted: 08/27/22 05:08pm Link  |  Quote  |  Print  |  Notify Moderator
valhalla360 wrote:
You appear to be within your axle ratings and GVWR.
The hitch weight is 320lb and is removing 100lb from your front axle (hence the 420lb increase in rear axle).
If your curb weight is accurate (iffy), you have 418lb of cargo/people in the SUV.
It sounds OK but....
Without a tow rating provided, I have no idea if you are exceeding your tow rating.
So how does is look and drive?
- Are the headlights pointing to the sky?
- Does the steering feel light?
- What is the hitch weight rating?
I believe 150 pound driver is included in the curb weight number.
* This post was edited 08/27/22 05:59pm by Me Again *
2021 F150 2.7 Ecoboost - Summer Home 2017 Bighorn 3575el. Can Am Spyder RT-L Chrome, Kawasaki KRX1000. Retired and enjoying it! RIP DW 07-05-2021
Me Again
Posted: 08/27/22 05:13pm Link  |  Quote  |  Print  |  Notify Moderator
My hitch weight scale:
