shadows4
Kansas City, Mo
Not my truck, trailer or hitch. Buddy of mine had this happen to him a couple of weeks ago. Said he did a pull test, all was good. When he pulled out of the campsite it disconnected. I do not have anymore pics than what are shown here. I think he must have missed the second hole when he pinned it. He has had this setup for about 4 years without a problem. He did hook it back up and drove 3 1/2 hrs to the next campground. What are your thoughts?
![[image]](https://i.imgur.com/Pe84l3Ml.jpg)
2003 4X4 F350,CC,SB,Lariat,7.3L diesel, 223,000 miles
2015 Coachmen Chapparal 324 TSRK
B&W Patriot 16K hitch.
bgum
South Louisiana
Thank all the cribbing in his bed or it would have been much worse.
Most likely he failed to hitch up completely.
dapperdan
Milwaukee
I'm NO expert but have owned a B & W hitch for 7 years and NEVER had anything like this happen! I'm sorry for your friend's predicament but IMHO that's operator error, sorry. ![frown [emoticon]](http://www.rv.net/sharedcontent/cfb/images/frown.gif)
Dan
Likes to tow
Huntington WV
B&W hitches are very good but if you don't get the handle all the way back and pin it correctly this can happen. Also if you get the kingpin over the jaws this can happen. A pull test should have caught this. Now I'm worried about my B&W pulling a trick like this!!
fj12ryder
Platte City, MO
Likes to tow wrote: B&W hitches are very good but if you don't get the handle all the way back and pin it correctly this can happen. Also if you get the kingpin over the jaws this can happen. A pull test should have caught this. Now I'm worried about my B&W pulling a trick like this!! The handle doesn't need to be pinned if it's in place. When you hook up, and the handle comes all the way back, the hitch is secure. You can pull out and the trailer will not come loose, even if you haven't pinned the handle.
You cannot put the kingpin over the jaws, unless you're blind. If you can't see a couple inches of clearance above the hitch head, then you probably should give up driving. ![smile [emoticon]](http://www.rv.net/sharedcontent/cfb/images/smile.gif)
This was operator error, pure and simple. I read about one guy that dropped his trailer with a B&W hitch, and it turns out he had pinned the hitch jaws open and forgot to remove the pin when hooking up. The jaws didn't close, the handle didn't move, and he still pulled out.
The guy just messed up. Happens to the best of us.
Howard and Peggy
"Don't Panic"
MFL
Midwest
I think most cases of a FW dropped on truck are operator error, no matter what hitch brand. Most hitch manufacturers instruct the operator to do a pull test, as does B&W. I can't speak for hitches I've no experience with, but with the B&W, IMO, a visual test is more reliable than a pull test.
If you can see the jaws wrapped completely around the center of pin, larger portion of pin showing on bottom, and you have the handle closed, locked with pin/padlock, you are hitched.
Now I remove chocks, do a walk around, steps up, FW door closed tight, nothing laying in path to pull out. All good...but look again just before jumping in truck. Yup jaws properly wrapped, handle closed/pinned, I'm GTG, no pull test needed.
So even if I got distracted unexpectedly, it happens, my last look confirms I am GTG. I am happy to say, I've never needed to redo my hookup.
Jerry
MFL
Midwest
Ha...your B&W is not capable of "pulling a trick" on you. It's like saying "who stole my glasses" when you don't remember where you put them.
Someone played a trick on you, took your keys, when you left them in your jacket pocket.
Yup, I've been there! ![smile [emoticon]](http://www.rv.net/sharedcontent/cfb/images/smile.gif)
Also I agree, by design of the B&W cam action jaws, you likely don't need the pin in handle, to tow your FW. It's kind of a Chinese handcuff thing, the harder you pull on the jaws, when fully wrapped around the pin, the tighter they hang on! Do I recommend trying this....nope!
Jerry
edited 08/26/22 06:24pm by MFL *
ford truck guy
Pennsylvania
Yup, Operator Error..
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
fj12ryder
Platte City, MO
MFL wrote: Likes to tow wrote: B&W hitches are very good but if you don't get the handle all the way back and pin it correctly this can happen. Also if you get the kingpin over the jaws this can happen. A pull test should have caught this. Now I'm worried about my B&W pulling a trick like this!!
Jerry Yeah, not a good idea to do it on purpose. But it has happened, and that person drove about a mile down the road out of the campground before he was informed he hadn't pinned the lever closed. But it wasn't me.
Fulltimer50
Kerrville, Tx
I dont understand some peoples obsession with not using proper procedures or included safety features. The pin in the handles is there for a reason why not us it? Is it soooo hard to do a pull test?
George
2011 F350 PSD CC LB 4X4 DRW Lariate
2015 Mobile Suites 41RSSB4 5th Wheel
