RV.Net Open Roads Forum: Class C Motorhomes: Leveling Blocks
 > Leveling Blocks
hotjag1
Lake Chelan, Wa/Lake Havasu, Az.
Posted: 08/30/22 12:25pm Link  |  Quote  |  Print  |  Notify Moderator
I use the 3 tier one piece levelers(like the ones pictured above) on the small rv in my signature. They are light weight and easy to handle, no worry of slivers, and the grab handle makes it easy to pick up from underneath.
hotjag1
2003 40' Allegro Bus, 3 slides, 400hp 8.9 liter ISL Cummins
2000 24' Dynamax Isata
joraz
Tucson
Posted: 08/30/22 12:42pm Link  |  Quote  |  Print  |  Notify Moderator
OP here. Went with 2X8s. They weigh about 13# apiece and I've got a compartment they just fit into. Thanks to all.
jor
ramp
09 LazyDaze
opnspaces
San Diego Ca
Posted: 08/30/22 03:45pm Link  |  Quote  |  Print  |  Notify Moderator
I have some that look like yours. After I built them I took them back apart and used a large hole saw from Harbor Freight and drilled a bunch of holes down the center between the two screw lines. I'm not sure if it matters but I made sure to stagger the holes between the levels. So far I've had no issues and it really lightened them up.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
time2roll
Posted: 08/30/22 04:06pm Link  |  Quote  |  Print  |  Notify Moderator
I would give what came with the RV a go. If/when they break get something else.
675w Solar pictures back up
joraz
Tucson
Posted: 08/30/22 04:48pm Link  |  Quote  |  Print  |  Notify Moderator
I'm likin' this idea. Thanks.
jor
 > Leveling Blocks
