RV.Net Open Roads Forum: Class A Motorhomes: Removal of gas strut
 > Removal of gas strut
jspringator
Versailles, KY 40383
Posted: 08/27/22 10:09am Link  |  Quote  |  Print  |  Notify Moderator
I can’t figure out how to remove a strut that holds open one of the cargo doors. The legend on the strut looks like the cover should pop up and it should release. But I can’t get the cover to pop up.
Any suggestions? 2002 Winnebago sightseer.
Jim & Sherri
02 Winnebago Sightseer 27c Class A;
"Scout" Springer Spaniel, gone but not forgotten;
"Boo" Chocolate Labradoodle.
MountainAir05
New Mexico
Posted: 08/27/22 10:21am Link  |  Quote  |  Print  |  Notify Moderator
After the first one it easy from then on.
https://www.youtube.com/watch?v=zVnbUbAbpZc
Sandia Man
Rio Rancho, NM
Posted: 08/27/22 10:24am Link  |  Quote  |  Print  |  Notify Moderator
On our Monaco there is a spring clip cover that we use a small flathead screwdriver to wedge loose. I have replaced a few of our cargo door struts and found them on Amazon, most struts are not model or brand specific, proper length and weight they can support is how we ordered them.
jspringator
Posted: 08/27/22 10:39am Link  |  Quote  |  Print  |  Notify Moderator
Unfortunately, mine aren't constructed like that. They have a plastic "cap" that looks like it should be pried up to release the ball. I tried to pry it off with a screw driver. I guess I need to pry harder! In the past I have just ripped them off, but in the process bent the holder.
[image]Untitled by jspringator, on Flickr
Horsedoc
Dixie --- N. Georgia
Posted: 08/27/22 02:41pm Link  |  Quote  |  Print  |  Notify Moderator
you are exactly right. Might be easier to remove the phillips screws and do it, Not hard to replace either
StarkNaked
West Seattle, WA
Posted: 08/27/22 05:09pm Link  |  Quote  |  Print  |  Notify Moderator
Take a closer look at the logo on your photo. My struts are something similar. I think "maybe" the cap is some sort of twist lock. Or does it lift up to release?
Do you have a better photo so we can read the info on that cap?
* This post was edited 08/27/22 05:25pm by StarkNaked *
StarkNaked
West Seattle, WA
Posted: 08/27/22 05:37pm Link  |  Quote  |  Print  |  Notify Moderator
I think I found it!!!
JR products
JR Products EF-PS130 Gas Spring End Fitting with Snap-On Cap.
This might not be the exact model you have, but it's real close!
jspringator
Posted: 08/27/22 06:06pm Link  |  Quote  |  Print  |  Notify Moderator
I already had the bottom one unscrewed. It has to come off no mater what. Then I twisted the top one off. I then put the bottom metal piece in a vice and twisted it off without bending it. I think I have 2 or 3 more to replace. I really can't complain; they are 20 years old.
ArchHoagland
Clovis, CA, USA
Posted: 08/28/22 01:07pm Link  |  Quote  |  Print  |  Notify Moderator
You could try spraying PB Blaster, WD40, etc on it the day before...might help.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
jspringator
Posted: 08/30/22 09:07am Link  |  Quote  |  Print  |  Notify Moderator
Good idea. That will make them easier to rip off!
